don't mean to panic maybe its not happening, but you would see the error
message on the server that vantage is running on. If you haven't seen any or
when you check your error log on the server and don't see anything. Then i
wouldn't change a thing.
Sent: Friday, October 13, 2000 11:40 AM
To: vantage@egroups.com
Subject: RE: [Vantage] Printing Issue with NT - SOLVED
To answer both responses:
Todd: Your suggestion about Regional Settings was correct. I found the
problem under number rather than currency.
Number was set to 0 digits, Currency set to 2 digits. Form looks great
now!
Mark: As far as I know I have not been getting msprov errors. What are
they and were do they show up? Maybe I will be digging into something
else now...
Thanks for making a huge amount of time troubleshooting reduced to 3
minutes! This onelist is great!
Juliet
now!
else now...
Juliet
