Problem: Checkbox select/deselect in record of PODetail table tr
robertb_versa@...
The specific field is PODetail.RcvInspectionReq; it's an Inspection checkbox
under Purchase Order Entry>Lines>Detail Tab.
I want a deselect / select of PODetail.RcvInspectionReq to deselect /
select same Part Number record in table.field: Part.Checkbox01 (a created
check box). I know I will have to include an adapter to perform this in dot
net. I am hoping to revise code and avoid reinventing the wheel if someone
has already designed something similar to my request.
We are presently Live on Epicor Vantage 8.03.407
Best Regards,
Herby Dallard
Information Technology Engineer
Endicott Research Group
hdallard@...
607-754-9187 ext. 3078
www.ergpower.com
_____
robertb_versa@...
Sent: Tuesday, September 15, 2009 4:59 PM
Subject: Re: [Vantage] Problem: Checkbox select/deselect in record of
PODetail table triggers checkbox select/des
What specific PO entry dataview boolean fields are you tring to set (&/or
what checkbox controls)?
Also - What version are you on?
PO entry is (one of many) 'works in process' as successive versions have
gone thru significant changes.
Rob
--- Original Message ---
From:"Herby Dallard" <hdallard@ergpower. <mailto:hdallard%40ergpower.com>
com>
Sent:Tue 9/15/09 4:39 pm
To:<vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com>
Subj:[Vantage] Problem: Checkbox select/deselect in record of PODetail table
All..I need a dot net code that can behave as outlined in subject. Anyone
who had to perform a similar task and may have used dot net or BPM or
anything please reply ASAC.
Thanks in advance.
Best Regards,
Herby Dallard
hdallard@ergpower. <mailto:hdallard%40ergpower.com> com
www.ergpower.com
