Another way to show say it is CustCnt.ShipToNum <= ""
for each Customer no-lock , each CustCnt no-lock where CustCnt.ShipToNum <= '""' And CustCnt.ConNum = Customer.PrimBCon and (Customer.Company = CustCnt.Company and Customer.CustNum = CustCnt.CustNum ).
--- In vantage@yahoogroups.com, Chris Thompson <chriselectrix@...> wrote:
> Is that assumeing ShorChar = 1?
> I see what it is doing but I couldnt think of a way around it.
> Is your code basically only going to show shiptonum = 0?
> Thanks,
> From: Kirstin Brandt <kirstin.brandt@...>
> To: vantage@yahoogroups.com
> Sent: Tuesday, 28 August 2012, 15:52
> Subject: [Vantage] Re: Problem with Cust Num
> ÂÂ
> Bob is probably a ship-to contact with the same contact ID as the primary billing contact. Try this (assuming you aren't using shorchar01 for anything else):
> for each Customer no-lock , each CustCnt no-lock outer-join where (Customer.Company = CustCnt.Company and Customer.CustNum = CustCnt.CustNum and Customer.ShortChar01 = CustCnt.ShipToNum and Customer.PrimBCon = CustCnt.ConNum ).
> --- In vantage@yahoogroups.com, Chris Thompson <chriselectrix@> wrote:
> > Hi All
> > I have encountered a problem with CustNum field.
> > I am trying to create a BAQ which will give me all of the contact names marked as 'Primary Bill To'.
> > So, I thought this would be easy ...
> > CUSTOMER <<< Join Company, CustNum, PrimBCon <<<< CustCnt
> > for each Customer no-lock , each CustCnt no-lock outer-join where (Customer.Company = CustCnt.Company and Customer.CustNum = CustCnt.CustNum and Customer.PrimBCon = CustCnt.ConNum ).
> > However, when I have checked, I have found some contacts have the same CustNum as another contact working for a different company, so some Customers are showing as having 2 primary billing contacts (which isnt possible) and only one of them actually works for the company in question.
> > Here is an example ...
> > Customer      CustNum(Customer)      PrimBCon      ConNum      CustNum(CustCnt)      Name
> > A               30000                        1                 1         30000                   Ted
> > A                   30000                               1                      1           30000                         Bob
> > Bob doesnt actually work for company A.
> > Does anyone else have this same problem?
> > Is there a fix for this?
> > Is there a work around? I am thinking along the lines of an additional TableRelation between Customer and CustCnt, but I cant find one.
> > Any help would be greatly appreciated.
> > Thanks,
> > CHRIS
