I do not use Report Builder so I do not know if it is affected. You may want to go on the Progress site and see if you can find SP3.
Dan Tisone
Operations / IT Consultant
dan.tisone@...
(949) 440-3685 x148
Cel (714) 227-4173
Sent: Monday, March 31, 2003 3:15 PM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Problem with Progress 9.1D SP5
I'm about 8 minutes away from installing this, I was just starting on 5.2
and as going to test it before using it for production.
Does the join problem only affect crystal or report builder too?. If I'm
not using the server for production should I still install it, since there
is no other patch available yet?.
Having the sp5 must be better than none at all.
Mark Howard
Financial Controller
Jaws Buckets & Attachments
This email, together with any attachments, is intended for the named
recipient(s) only and may contain privileged and confidential information.
No information within this email can be forwarded via email or verbally
without the consent of the sender.
If not an intended recipient of this email, you must not copy, distribute or
rely upon it and any form of disclosure, modification, distribution and/or
publication of this email is prohibited.
Unless stated otherwise, this email represents only the views of the sender
and not the views of Jaws Buckets & Attachments.
Sent: Tuesday, April 01, 2003 8:47 AM
Subject: [Vantage] Problem with Progress 9.1D SP5
I wanted to let everyone know about an issue with the Progress 9.1D service
pack; Crystal Reports using Left Outer Joins may not work properly. I have
experienced this problem first hand and had to roll back to SP3. Apparently
Progress knows about this as can seen in the below report.
This is a Progress problem not a Vantage problem, but I have already asked
them to pull this service pack off the Vantage site. I suggest you all give
them some pressure as well.
Dan Tisone
dan.tisone@...
(949) 440-3685 x148
Cel (714) 227-4173
Progress Solution
Title: "Impredictable result when using OUTER JOIN with 91D Service Pack 05"
Created: 18-Mar-2003 Last Modified: 18-Mar-2003
Status: Unverified
Symptom(s):
* Impredictable result when using OUTER JOIN with 91D Service Pack 05
* The problem does not occur in a previous Service Pack
* The bug results to either returns wrong results or no result at all
* Query can be executed using SQL Explorer
* The Query that shows the problem is similar to the following :
SELECT * FROM ORDER, ACCOUNT WHERE ACNT_ID (+) = ORD_ISSUER AND
ACNT_LOGINNAME = 'test';
Cause(s):
* Known issue
Fix:
There is no fix available at the time of this writting
------------------------ Yahoo! Groups Sponsor ---------------------~--> Get
128 Bit SSL Encryption!
http://us.click.yahoo.com/xaxhjB/hdqFAA/VygGAA/PhFolB/TM
ADVERTISEMENT
<http://rd.yahoo.com/M=246920.2960106.4328965.1728375/D=egroupweb/S=1705007183:HM/A=1513704/R=0/*http://www.gotomypc.com/u/tr/yh/cpm/grp/300_02F/g22lp?Target=mm/g22lp.tmpl>
<http://us.adserver.yahoo.com/l?M=246920.2960106.4328965.1728375/D=egroupmail/S=:HM/A=1513704/rand=687380220>
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
Dan Tisone
dan.tisone@...
(949) 440-3685 x148
Cel (714) 227-4173
Mark Howard
Dan Tisone
dan.tisone@...
(949) 440-3685 x148
Cel (714) 227-4173
Progress Solution
Status: Unverified
Symptom(s):
Cause(s):
* Known issue
Fix:
ADVERTISEMENT
