I see the date on this question is very old.
Did you not get any answer on this?
Did you eventually find out more on how Production Yield works?
If I am reading the Production Yield settings correctly then if I have a stock job that call for a qty of 10 and has three operations to if, if the 1st op completes 10, than the 2nd op completes 9, the Production Yield optinos would be to send an alert out that only 9 are made or re-calculate the job qty down to 9. Is that correct?
Scott
