Im not able to access Aged Payable report and Receipt entry. What should to fix this?
Application Error
Error Detail
##!Message:##! Cannot access this menu item: Receipt Entry
##!Inner Exception Message:##! Table ‘XbSyst’ property mismatch between sender and receiver.
##!Program:##!
##!Method:##!
Inner Exception
Server stack trace:
at Ice.IceTableset.Deserialize(Stream stream)
at Ice.IceTablesetSurrogate.GetDeserializedObject(Object obj, Type targetType)
at System.Runtime.Serialization.XmlObjectSerializerReadContextComplex.InternalDeserializeWithSurrogate(XmlReaderDelegator xmlReader, Type declaredType, DataContract surrogateDataContract, String name, String ns)
at System.Runtime.Serialization.XmlObjectSerializerReadContextComplex.InternalDeserialize(XmlReaderDelegator xmlReader, Type declaredType, DataContract dataContract, String name, String ns)
at System.Runtime.Serialization.DataContractSerializer.InternalReadObject(XmlReaderDelegator xmlReader, Boolean verifyObjectName, DataContractResolver dataContractResolver)
at System.Runtime.Serialization.XmlObjectSerializer.ReadObjectHandleExceptions(XmlReaderDelegator reader, Boolean verifyObjectName, DataContractResolver dataContractResolver)
at System.Runtime.Serialization.DataContractSerializer.ReadObject(XmlDictionaryReader reader, Boolean verifyObjectName)
at System.ServiceModel.Dispatcher.DataContractSerializerOperationFormatter.PartInfo.ReadObject(XmlDictionaryReader reader, XmlObjectSerializer serializer)
at System.ServiceModel.Dispatcher.DataContractSerializerOperationFormatter.DeserializeParameterPart(XmlDictionaryReader reader, PartInfo part, Boolean isRequest)
at System.ServiceModel.Dispatcher.DataContractSerializerOperationFormatter.DeserializeParameter(XmlDictionaryReader reader, PartInfo part, Boolean isRequest)
at System.ServiceModel.Dispatcher.DataContractSerializerOperationFormatter.DeserializeBody(XmlDictionaryReader reader, MessageVersion version, String action, MessageDescription messageDescription, Object parameters, Boolean isRequest)
at System.ServiceModel.Dispatcher.OperationFormatter.DeserializeBodyContents(Message message, Object parameters, Boolean isRequest)
at System.ServiceModel.Dispatcher.OperationFormatter.DeserializeReply(Message message, Object parameters)
at System.ServiceModel.Dispatcher.ProxyOperationRuntime.AfterReply(ProxyRpc& rpc)
at System.ServiceModel.Channels.ServiceChannel.HandleReply(ProxyOperationRuntime operation, ProxyRpc& rpc)
at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object ins, Object outs, TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannelProxy.InvokeService(IMethodCallMessage methodCall, ProxyOperationRuntime operation)
at System.ServiceModel.Channels.ServiceChannelProxy.Invoke(IMessage message)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at Erp.Contracts.CompanySvcContract.GetByID(String company)
at Erp.Proxy.BO.CompanyImpl.GetByID(String company)
at Erp.Adapters.CompanyAdapter.OnGetByID(String ID)
at Ice.Lib.Framework.EpiBaseAdapter.GetByID(String stringId)
at Erp.UI.App.ReceiptEntry.Transaction.TransactionLoad()
at Ice.Lib.Framework.EpiTransaction.createTransaction()
at Ice.Lib.Framework.EpiTransaction..ctor(Object Sender)
at Erp.UI.App.ReceiptEntry.Transaction..ctor(Object Sender)
at Ice.Lib.App.Launch.InitializeLaunch()
at Ice.Lib.Framework.EpiBaseLaunch.lShow(Object args, DataSet dsMenuItem)
at Ice.Lib.App.Launch.lShow(Object args, DataSet dsMenuItem)
at Ice.Lib.Framework.FormFunctions.Launch(Session session, DataRow menuRow, String program, Object lfo)
at Ice.Lib.Startup.LaunchUIApp(MenuRow menuRow, Session session, Form& form, Object lfo)
Application Error
Error Detail
##!Message:##! Cannot access this menu item: Aged Payables
##!Inner Exception Message:##! Table ‘APAgedPayableReportParam’ property mismatch between sender and receiver.
##!Program:##!
##!Method:##!
Inner Exception
Server stack trace:
at Erp.Contracts.APAgedPayableReportSvcContract.GetNewParameters()
at Erp.Proxy.Rpt.APAgedPayableReportImpl.GetNewParameters()
at Erp.Adapters.APAgedRecReportAdapter.GetNewParameters()
at Erp.UI.Rpt.APAgedRecReport.Transaction.adapterGetNewParameters()
at Ice.Lib.Framework.EpiReportTransaction.GetNewParameters()
at Erp.UI.Rpt.APAgedRecReport.Transaction.TransactionLoad()
at Ice.Lib.Framework.EpiReportTransaction..ctor(Object Sender)
at Erp.UI.Rpt.APAgedRecReport.Transaction..ctor(Object Sender)
