Proxml.dll error when installing 9.05.603 Service Pack
Admin Tools and Schema Changes are 32-bit only. It is in the install guide...buried...but it's there. Says that 64-bit installs require a 32-bit workstation. We encounter this issue with practically every client we visit. We pretty much make it clear that the client will need a dedicated "Admin" workstation.
Jason Claggett
Microsoft Small Business Specialist
MCP #3856159
2W Technologies, LLC
Epicor Silver Partner
312.533.4033 x8039
jason@...<mailto:jason@...>
[cid:image001.jpg@...189600]
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of sbraudrick@...
Sent: Tuesday, March 01, 2011 7:05 AM
Subject: [Vantage] Re: proxml.dll error when installing 9.05.603 Service Pack
I seem to have resolved this by running the conversions on a 32-bit Admin Workstation. I guess this is another "feature" of the 64-bit Progress.
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "sbraudrick@...<mailto:sbraudrick@...>" <sbraudrick@...<mailto:sbraudrick@...>> wrote:
> I've installed the 9.05.603 Service Pack following the Install Guide from Epicor and am in an infinite loop of the following two errors when running the Database Conversions:
> 1.) The proxml.dll or libproxml.so was missing or incomplete or XML could not be initialized. (9088)
> 2.) Cannot create widget of type X-DOCUMENT. (3181)
> The errors pop up during program cv/cvpe0000.p / Description: Loading Posting Engine data. / Processing messages: Merge Process.
> We are on Windows Server 2008 R2 64-bit running on Progress 64 bit.
> A quick Google search leads me to believe this has something to do with Progress but it is geared toward a *NIX installation and I'm not able to translate it to Windows (if it's even possible). http://www.peg.com/forums/peg/200903/msg00125.html
> Has anyone else run in to this and found a solution?
> -Sean
-Sean
Are you running the conversions on a 32 bit install of progress?
> -Sean
> -Sean
That was the problem, I was trying it on the 64 bit progress install on the server.
> > -Sean
