How can I add the DMR number to an email created by a BPM each time your check the Check Offs boxes like QA, Engineering, Production etc.
See attachment
Thank you in advance.
DMR Number in Email.docx (293.1 KB)
See attachment
if you right click in the body and select “Field Query…”, you can reference fields related to the BPM.
Then the message template shows:
You can click on that “link” to change the settings of that Field Query if you need to.
Thank you so much. This works great! Be well!
