>>Fullfillment Workbench - allocated, reservedThanks that did the trick.
Hi,
Anyone seen this error in Sales Order entry before?
"Quantity cannot be decreased below the reserved or allocated quantity".
E9.05.702A - Sales Order entry
When trying to change a line Qty from 12 to 9.
The Sales Order line has a related make-to-order Job.
Thanks in advance
In sales order entry. click actions then reserve / allocate.
this brings up the fulfillment wb.
select your order then click actions > unallocated and unreserved
This will typically clear the issue. If not then close the releases, lines and order and reopen them
Greg
Sent: Friday, February 13, 2015 4:42 PM
Subject: [Vantage] Quantity cannot be decreased below the reserved or allocated quantity
Hi,
Thanks in advance
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
