Allocated QTY Issue
In an order we are wanting to add a release, one for 1500 and the other for 1000 instead of line one release one being 2500. Except when we try to change it, we get:
Business Layer Exception
Quantity of this release cannot be decreased below the Reserved or Allocated quantity.
Error Detail
Correlation ID: 0d49a8d7-576e-473f-820f-3f8a8c480371
Description: Quantity of this release cannot be decreased below the Reserved or Allocated quantity.
Program: Erp.Services.BO.SalesOrder.dll
Method: OrderRelBeforeUpdate
Line Number: 25814
Column Number: 21
Table: OrderRel
Field: OurReqQty
Client Stack Trace
at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets)
at Erp.Proxy.BO.SalesOrderImpl.MasterUpdate(Boolean lCheckForOrderChangedMsg, Boolean lcheckForResponse, String cTableName, Int32 iCustNum, Int32 iOrderNum, Boolean lweLicensed, Boolean& lContinue, String& cResponseMsg, String& cCreditShipAction, String& cDisplayMsg, String& cCompliantMsg, String& cResponseMsgOrdRel, String& cAgingMessage, SalesOrderDataSet ds)
at Erp.Adapters.SalesOrderAdapter.MasterUpdate(Boolean lCheckForOrderChangedMsg, Boolean lcheckForResponse, String cTableName, Int32 iCustNum, Int32 iOrderNum, Boolean lweLicensed, Boolean& lContinue, String& cResponseMsg, String& cCreditShipAction, String& cDisplayMsg, String& cCompliantMsg, String& cResponseMsgOrdRel, String& cAgingMessage)
at Erp.UI.App.SalesOrderEntry.Transaction.Update()
Based on the error message, you’ll have to unreserve this line in Fulfillment Workbench before you can make changes to the quantities.
We’re running into the same error when trying to reduce an order release quantity. I went into fulfillment workbench, pulled up the release on the Order Fulfilment tab, selected it, then unallocated/unreserved. I’m still getting the error in order entry unfortunately. Am I doing something wrong?
Does the reserved quantity say 0 on the specific line/release ?
No it is still the original release quantity of 6.
