With just progress installed, you cannot compile your progress code, persay.
You have to buy the Progress Programming Toolkit (or whatever it is called)
for a couple thousand dollars. Then you can make really fance programs more
easily, with windows and dialog boxes, etc. The compiled code probably runs
much faster.
With Progress installed that comes with Vantage you could technically run
those fancier programs, but you would have to design all your own widgets,
windows, and wuffers (buffers) "on the fly". For simple programs, Progress
works great. If you want to do fancy stuff, you might want to buy the full
package. Other's, perhaps, could speak to that.
Troy
jrecto@...]
Sent: Monday, July 21, 2003 9:46 AM
To:
vantage@yahoogroups.com
Subject: RE: [Vantage] .r files
What's the point of having a compiled report? Are we able to take a
compiled report an revert it back to the source code?
Jasper
tfunte@...]
Sent: Monday, July 21, 2003 9:43 AM
To:
Jasper,
If you have progress installed on any client machine, you can write
your
own code. I have written progress code to do exports from Vantage. You
can
also use other means. Most simple way to start would be to create a blank
file on your desktop like "test.p". (I use .p for my progress code). Now
double-click the test file and it should open in "Procedure Editor". This
is is where you can write code. Click on HELP to access Progress
commands.
You don't need a compiler to run the code. Just right-click and select
RUN
(or press F2, or click Compile/Run from the menu). If you are accessing
the
Vantage Database, you will also need a connection to the database. To do
this, right-click and select "Insert Database Field". It will tell you
you
need to be connected and bring up the connection window. Fill in the
appropriate fields for Connecting to the Database... Similar to the report
builder settings. When done, you should be able to see your Vantage
fields
and tables.
Once you have written your code, you can run it from a command line if
desired, or from VBForm fields.
Have fun, and keep asking questions. There are some good documents
(Programmers Handbook, and Progress Help) on the Progress website.
Troy Funte
Liberty Electronics
jrecto@...]
Sent: Monday, July 21, 2003 9:31 AM
To:
What software do you need to create/compile your own code?
Jasper
JimM@...]
Sent: Monday, July 21, 2003 9:15 AM
To:
The .r files are compiled Progress code (.w or .p and .i files).
The .w and .p files are Progress source code.
A .i file is an include file (repetitive code included in more than one
source code file).
Jim
jrecto@...]
Sent: Friday, July 18, 2003 4:10 PM
To: Vantage Groups (E-mail)
Subject: [Vantage] .r files
What are .r files? What are .p and .w files?
Jasper
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
Yahoo! Groups Sponsor
ADVERTISEMENT
http://rd.yahoo.com/M=251812.3170658.4537139.1261774/D=egroupweb/S=17050071
83:HM/A=1652964/R=0/SIG=11t2ts2ch/*
http://www.netflix.com/Default?mqso=60178
276&partid=3170658> click here
http://us.adserver.yahoo.com/l?M=251812.3170658.4537139.1261774/D=egroupmai
l/S=:HM/A=1652964/rand=357088929>
and
http://docs.yahoo.com/info/terms/> .
ADVERTISEMENT
and
ADVERTISEMENT
http://rd.yahoo.com/M=244522.3512152.4794593.1261774/D=egroupweb/S=17050071
83:HM/A=1595056/R=0/SIG=124bf4lrb/*
http://ashnin.com/clk/muryutaitakenattogy
o?YH=3512152&yhad=1595056> Click Here!
http://us.adserver.yahoo.com/l?M=244522.3512152.4794593.1261774/D=egroupmai
l/S=:HM/A=1595056/rand=775988084>
ADVERTISEMENT
