Checking to see if anyone else is having issues with data from linked tables appearing on reports?
As an example, I have a custom PackSlip RDD where I used the JobNum linked table on ShipDtl to bring in CreateDate and ProdQty. However, the fields on the report show no data.
This is where I miss being able to query the report database.
Mr. John: I know one thing that always seems to get me - is when i am adding the Field names to the dataset (not the Select Query) in SSRS and I misspell the field name. The report will run without error (at least for SaaS customers) but the field will show blank.
I try to always use the Link fields whenever i can (easier than adding a table and fields).
I meant Dave’s suggestion is the answer. If you use a linked table you need to add the reference in your query. Now that I am re-reading it though I see he meant misspelling it in your Query fields section. That very well could be.
