I would also like to see an extra digit or two. Our base unit for raw
material inventory is inches. Most raw material comes in 12' (144")
lengths. The dimensional conversion factor is 1/144" =
.006944444444444...
We generally override the conversion factor, and dollars seem to work
ok.
Bruce Butler
IT Manager
Knappe & Koester, Inc.
_____
Of ami_miker
Sent: Monday, November 13, 2006 9:07 AM
Subject: [Vantage] Re: RECEIVING SUPPLIER QTY"S?????
I have had the same frustrations with the UOM issues. For your
first situation, one of our clients added the conversion information
into the part description. The receiver wouldn't have to weigh the
shipment, but they would still have to manually convert from each to
lbs.
The conversion factor is extremely frustrating. The conversion
factors are some of the most detail limiting numeric fields in
Vantage. In a lot of cases, just one more digit (like many other
numerics) would help tremendously. Sorry - no suggestions here.
Michael Randolph
Infinity Business Consulting
mrandolph@... <mailto:mrandolph%40infinitybc.com>
.006944444444444...
ok.
Bruce Butler
IT Manager
_____
Of ami_miker
lbs.
Michael Randolph
>in
> When a company orders metal from a vendor, they usually purchase
> industry standard of $$/lbs.vendors
> When a company receives items into stock, they do not use the
> unit of measure but the companies (typically each)we
> Vantage forces the receiver to use the suppliers unit of measure
> regardless of PO or our unit of measure.
> Receivers do not weigh trucks or the product being unloaded from
> those trucks. They count in our unit of measure how many pieces
> received.of
> Vantage will convert the suppliers unit of measure to our qty unit
> measure but not the other way around.our
> When a supplier shorts us from what is listed on the del tkt,
> truckers and your receiving personnel will adjust the del tkt in
> qty (each) not the supplier qty (lbs) - primarily because they aremy
> not weighing the units they offload from the truck) By the way -
> receiver is not working for my suppliuer therefore counts in myunit
> of measure not the suppliers.supposed
> In this case, note how the receiver and the trucker both verified
> that we received only 2 of the 3 unites (each) that we were
> and that were listed on the del tkt. The load was supposed tothe
> contain all 3 pcs and likewise reflected the suppliers unit of
> measure in lbs but now Vantage is expecting my receiver to know
> factor & convert the actual received supplier qty while he isunit
> standing on the back of a semi.
> I have one other issue in that my suppliers like to round their
> of measure which causes me to receive 2.99 pcs or 4.01 pcs, etc.I
> need control of this without depending on my suppliers systemgetting
> it correct. My system, my numbers, my factors, our unit ofmeasure
> is what is used here.errors?
> By receiving the supplier qty in I would have eventually paid for
> product that I did not receive. Can I bill Vantage for these
>[Non-text portions of this message have been removed]
