Remote App MES always seems to log a trace and other RDP glitchi
For reference, I found out what the problem is.
Tracing is enabled per computer, using the mfgsys.exe.config file. Set the DataTrace value to 0 to disable tracing. I had deployed a number of users with this config, which is where the problem was.
This is one of those silly and frustrating things that I think that Tier 1 support should know about.
--- In vantage@yahoogroups.com, "Brian Roberts" <broberts@...> wrote:
> As a guess: enable customization privs for that MES user, so you can get
> to tracing. And turn them back off later, of course.
> Brian.
> Of cubcrafters_it
> Sent: Wednesday, February 08, 2012 2:19 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Remote App MES always seems to log a trace and
> other RDP glitchies
> So that's what the Epicor Tech suggested. I logged in as my user and
> sure enough, tracing was on. I thought it was a per instance thing.
> *However*, I logged in with /MESC using one of our MES users, and I
> don't have the right-click option for Tracing at all.
> Any ideas there?
> As far as the other RDP issues, we run RDP for our second location over
> the VPN. They're on ethernet to the switch over there, but then have to
> traverse the VPN, so there's a speed hit there, but it's not terrible.
> Sometimes upon connecting to the RemoteApp they just see a black screen,
> and again I have to go and bump the session.
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> "Brian Roberts" <broberts@> wrote:
> > I see mention of the tracedata file and GB worth of logs... is it
> > possible that tracing was turned on for the MES username and never got
> > turned off? Would explain intermittent conflicts trying to write to
> the
> > same file. To fix: start Epicor with /MESC, right click in the main
> > screen & disable tracing.
> > Brian.
> > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Behalf
> > Of cubcrafters_it
> > Sent: Friday, February 03, 2012 11:28 AM
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > Subject: [Vantage] Remote App MES always seems to log a trace and
> other
> > RDP glitchies
> > (9.05.607A Progress 32-bit)
> > So every once in a while when starting MES through our Remote Desktop
> > server, the client sees an Access Denied message to a TraceData.txt
> > file.
> > Often launching the app again will get around it, but I finally looked
> > at the log folder today, and there's over 2 GB of log files in there.
> > Is there a setting I'm missing that will disable tracing all the time?
> > Also, occasionally our remote MES users won't be able to get into MES
> at
> > all, and the app just appears to hang. I've got to go onto the remote
> > server, boot their session, and usually they're okay after that. But
> > it's a little bit of a hassle to have to maintain it that way.
> > Has anyone else had this kind of problem, and how have you resolved
> it?
So every once in a while when starting MES through our Remote Desktop server, the client sees an Access Denied message to a TraceData.txt file.
Often launching the app again will get around it, but I finally looked at the log folder today, and there's over 2 GB of log files in there.
Also, occasionally our remote MES users won't be able to get into MES at all, and the app just appears to hang. I've got to go onto the remote server, boot their session, and usually they're okay after that. But it's a little bit of a hassle to have to maintain it that way.
Has anyone else had this kind of problem, and how have you resolved it?
Hi Jason,
How is your remote connection running?
I had MES trouble like you describe on a dodgy wireless network.
Running CAT5 to the workstations fixed the problem.
MES seems to be sensitive to network issues.
--- In vantage@yahoogroups.com, "cubcrafters_it" <jason.navarrete@...> wrote:
turned off? Would explain intermittent conflicts trying to write to the
Brian.
Of cubcrafters_it
Subject: [Vantage] Remote App MES always seems to log a trace and other
RDP glitchies
file.
So that's what the Epicor Tech suggested. I logged in as my user and sure enough, tracing was on. I thought it was a per instance thing.
*However*, I logged in with /MESC using one of our MES users, and I don't have the right-click option for Tracing at all.
Any ideas there?
As far as the other RDP issues, we run RDP for our second location over the VPN. They're on ethernet to the switch over there, but then have to traverse the VPN, so there's a speed hit there, but it's not terrible.
Sometimes upon connecting to the RemoteApp they just see a black screen, and again I have to go and bump the session.
> Brian.
> Of cubcrafters_it
> RDP glitchies
> file.
Brian.
Of cubcrafters_it
other RDP glitchies
Any ideas there?
the
> Brian.
Behalf
> Of cubcrafters_it
other
> RDP glitchies
> file.
at
it?
