Is it possible to rename the grid column header using something like
Description {UD104.Character01}
I tried this but it’s not reading the column inside brackets as field
I have not tested but “Extended Properties Maintenance” has a field called “Label” for displaying the name you want to use for user defined fields.
Hi Sr i wanted actually to display some static label like Description + dynamic name that comes from field like {UD104.Character01} , is Extended Properties Maintenance available in kinetic and how I cand find it ?
Menu Search or
System Setup/System Maintenance/Extended Properties
