Report Builder Print Problem with HP 2100TN printer
We ended up using HP Laserjet II series driver instead of HP 2100M driver
for Vantage or RB printing. It's working fine.
Mike Tonoyan / MIS Manager
All American Products Co.
1135 Aviation Place
San Fernando, CA 91340
USA
Tel.: 818-361-0059 Ext.: 246
Fax 818-898-2236
E-mail: miket@...
Web: www.allamericanproducts.com
----- Original Message -----
To: "VANTAGE" <vantage@yahoogroups.com>
Sent: Wednesday, November 21, 2001 6:25 AM
Subject: [Vantage] Report Builder Print Problem with HP 2100TN printer
> Am having a problem with Report Builder reports printing on an HP 2100TN
LaserJet printer. The printer is networked using HP Jet Direct.
> The problem is that any Report Builder reports will not print unless we
push the "GO" button on the printer. This is true if we print from Vantage
or directly from Report builder. Printing from any other application works
okay. Also printing Crystal forms works okay also.
> I have downloaded and installed the latest driver from HP, but this didn't
help.
> Any hints?
> Jerry Brunner
> Quala-Die, Inc.
> 1250 Brusselles Street
> St. Marys, PA 15857
> 814.781.6280
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Am having a problem with Report Builder reports printing on an HP 2100TN LaserJet printer. The printer is networked using HP Jet Direct.
The problem is that any Report Builder reports will not print unless we push the "GO" button on the printer. This is true if we print from Vantage or directly from Report builder. Printing from any other application works okay. Also printing Crystal forms works okay also.
I have downloaded and installed the latest driver from HP, but this didn't help.
Any hints?
Jerry Brunner
Quala-Die, Inc.
St. Marys, PA 15857
814.781.6280
I'm not positive, but I think Report Builder saves printer settings per
report. You could try opening the report in Report Builder, go to Print
Properties and make sure it's not printing to manual feed. Just a thought.
- Ed
Sent: Wednesday, November 21, 2001 8:25 AM
To: VANTAGE
help.
Any hints?
Jerry Brunner
Quala-Die, Inc.
St. Marys, PA 15857
814.781.6280
Yahoo! Groups Sponsor
<http://rd.yahoo.com/M=212180.1701098.3252983.1269402/D=egroupweb/S=17050071
83:HM/A=812074/R=0/*http://www.verisign.com/cgi-bin/go.cgi?a=b15334027000300
0>
<http://us.adserver.yahoo.com/l?M=212180.1701098.3252983.1269402/D=egroupmai
l/S=1705007183:HM/A=812074/rand=715585117>
Thanks, but it is set to Auto Select (2 trays).
Jerry
per
Print
thought.
> - Ed
> From: Jerry Brunner [mailto:jbrunner@q...]
> To: VANTAGE
printer
2100TN
unless we push
Vantage or
works
didn't
> help.
> Any hints?
> Jerry Brunner
> Quala-Die, Inc.
> St. Marys, PA 15857
> 814.781.6280
050071
a=b15334027000300
> 0>
must have
Builder and
>LaserJet printer. ...any Report Builder reports will not print unless we
We have a 2100 here that does the same thing, interfaced via either an Axis
print server or parallel cable. I never was able to make it work with the
stock drivers. But IIRC, something on HP's web site suggested it might be
a firmware bug in very early production models (which this one is.) No
cheap way to update it, unfortunately.
As a work around, try using the driver for an older HP. I think the 6P one
worked well, and has all the features.
-Wayne Cox
