RestAPI Response Code Error
Hi, i am trying to integrate Epicor and FEDEX API, it was going quite well until i had to define the Json reponse for creating a shipment in a code block.
I currently have the definition code. but all i can return is definitioncc does not exist in this context.
I believe it is to do with the arrays but i have gotten lost and i am struggling with it.
var definitioncc = new {
transactionId = “”,
output = new {
transactionShipments = new [] { new {
masterTrackingNumber = “”,
serviceType = “”,
shipDatestamp = “”,
serviceName = “”,
pieceResponse = new [] { new {
trackingNumber = “”,
additionalChargesDiscount = 0.0,
netRateAmount = 0.0,
netChargeAmount = 0.0,
netDiscountAmount = 0.0,
packageDocuments = new [] { new {
contentType = “”,
copiesToPrint = 0,
encodedLabel = “”,
docType = “”
customerReferences = new [] {""},
codcollectionAmount = 0.0,
baseRateAmount = 0.0
completedShipmentDetail = new {
usDomestic = false,
carrierCode = “”,
masterTrackingId = new {
trackingIdType = “”,
formId = “”,
trackingNumber = “”
serviceDescription = new {
serviceId = “”,
serviceType = “”,
code = “”,
names = new [] { new {
type = “”,
encoding = “”,
value = “”
        operatingOrgCodes = new [] {""},
        serviceCategory = "",
        description = "",
        astraDescription = ""
                                                      packagingDescription = "",
                                                      operationalDetail = new {
        ursaPrefixCode = "",
        ursaSuffixCode = "",
        originLocationId = "",
        originLocationNumber = 0,
        originServiceArea = "",
        destinationLocationId = "",
        destinationLocationNumber = "",
        destinationServiceArea = "",
        destinationLocationStateOrProvinceCode = "",
        deliveryDate = "",
        deliveryDay = "",
        commitDate = "",
        commitDay = "",
        ineligbleForMoneyBackGuarantee = false,
        astraPlannedServiceLevel = "",
        astraDescription = "",
        postalCode = "",
        stateOrProvinceCode = "",
        countryCode = "",
        airportId = "",
        serviceCode = "",
        packagingCode = "",
        publishedDeliveryTime = "",
        scac = ""
                                                      completedPackageDetails = new [] { new {
        sequenceNumber = 1,
        trackingIds = new [] { new {
        trackingIdType = "",
        formId = "",
        trackingNumber = "",
        groupNumber = 0,
        signatureOption = "",
        operationalDetails = new {
        barcodes = new {
        binaryBarcodes = new [] { new {
        type = "",
        value = ""
        stringBarcodes = new [] { new {
        type = "",
        value = ""
        astraHandlingText = "",
        operationalInstructions = new [] { new {
        number = 0,
        content = ""
                                                       documentRequirements = new {
        prohibitedDocuments = new [] {"", ""}
Here’s a lazy way to create JSONs. Alternatively, you can create classes and use those instead of JObject and JArray
    // define call object
    objTCall = new Newtonsoft.Json.Linq.JObject();
    // call object fields
    objTCall.interfaceId = rpInterfaceID;
    objTCall.syncValidate = true;
    // define orders array
    objOrderArray = new Newtonsoft.Json.Linq.JArray();
    // order
    objOrder = new Newtonsoft.Json.Linq.JObject();
    objOrder.salesOrderRef = tSONo;
    objOrder.consigneeRef = eSONo.ToString(); // our SO No
    objOrder.status = "NEW";
    // add order to array
    objOrderArray.Add(objOrder);
    // set orders
    objTCall.orders = objOrderArray;
    // serialize for rest call
    string sbdy = Newtonsoft.Json.JsonConvert.SerializeObject(objTCall);
