Salvage material transactions
You will also need to put the price of the salvaged material in "cost
adjustments".
Kathy Schaich
Operations Support Manager
Ultra Tool & Manufacturing, Inc.
W169 N5954 Ridgewood Drive
Menomonee Falls, WI 53051
Phone: 262-703-0455
Fax: 262-703-0468
Toll Free: 800-779-3566
kathy.schaich@...
www.ultratoolmfg.com
The information contained in this electronic message (email) and any
attachment(s) to it is/are intended for the exclusive use of the intended
addressee(s) and may contain information that is confidential and/or
privileged and exempt from disclosure under applicable law. If you are not
the intended recipient(s) and have received this communication in error,
please do not distribute it. Instead, please notify Ultra Tool &
Manufacturing, Inc. at 1-800-779-3566 or by email at
general@... and destroy all copies of this message and any
attachments. Thank you.
Robert Brown
Sent: September 15, 2008 7:20 PM
Subject: Re: [Vantage] Salvage material transactions
The only aspect of it that I'm sure of is that you have to set up your
method with at least one of your raw materials having a salvage part number
& qty per indicated.
When you receive from the Job, you can then receive not only what you were
primarily producing on the job - but also the actual salvage part qty.
We just started doing this on a temporary basis to utilize some dead
(activity) subassembly SKUs with other common subcomponents (in place of
things we would otherwise have to wait 6-8 weeks to buy order for order).
So far, it seems to be working on 405a.
Rob Brown
--- On Mon, 9/15/08, jimlmm24521 <jimlmm24521@
<mailto:jimlmm24521%40yahoo.com> yahoo.com> wrote:
From: jimlmm24521 <jimlmm24521@ <mailto:jimlmm24521%40yahoo.com> yahoo.com>
Subject: [Vantage] Salvage material transactions
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
Date: Monday, September 15, 2008, 4:01 PM
Where does the salvage transaction have to be set up initially?? I
have been looking and have tried some things, but nothing is working.
When you add the material to the BOM and routing, select the material
salvage tab to add the part number and qty of material that will be salvaged
from the job. When the job is complete you can receive the salvage material
to stock using the Salvage Materials Receipts transaction.
_____
jimlmm24521
Sent: Monday, September 15, 2008 3:01 PM
The only aspect of it that I'm sure of is that you have to set up your method with at least one of your raw materials having a salvage part number & qty per indicated.
When you receive from the Job, you can then receive not only what you were primarily producing on the job - but also the actual salvage part qty.
We just started doing this on a temporary basis to utilize some dead (activity) subassembly SKUs with other common subcomponents (in place of things we would otherwise have to wait 6-8 weeks to buy order for order).
Rob Brown
