Saved Dashboard Layout Does Not Retain Collapsed Group By State
Happy Twos Day!
We are experiencing an issue where a saved dashboard layout does not retain the collapsed state of grouped rows.
When we first apply a Group By, save the layout, and refresh the dashboard, the grouped rows correctly remain collapsed (as expected).
However, after closing and reopening the dashboard, the Group By is still applied, but the collapsed state is no longer retained, and all groups load expanded.
CreditHoldDash
To try and trouble shoot we looked through some App Studio settings reviewing: Panel Grid > Advanced > Exapnd at Run Time and Panel Grid > Data Grid Model > Collapse Groups
We found that when we unselect ‘Collapse Groups’ the intial Group By (before saving the layout) is expanded. Is this setting half baked??
Epi Users Article - Kinetic Grid Groups expand all/collapse all seemed promising but did not work in our intial pass through.
Has anyone else encountered this or have suggestions on how we can reach our end goal of having the Group By remain collapsed?
Quick bump, running into this on other dashboards and would appreciate any guidance.
Kinetic dashboards are garbage sadly compared to classic.
I have two different behaviors with group bys → save layouts.
One the same as yours.
The other cause no data to load unless you turn off the group by and turn it back on defeating the purpose of saving the layout.
Thanks, James!
It’s nice to know there’s a whole minefield out there…
If I find a fix for the first I’ll keep you posted and hope you will do the same :handshake:
We are having the same issue. Anyone know of a solution yet?
None that I am aware of. This is still an open issue for us as well :melting_face:
