Did you remember to rerun the Vantage Invoice again (before opening
the CR) after you modified your data definitions? After re-running
the report, then you update your Datasource Location in the CR.
You can get AnswerBook # 4778MPS from the Epicor website & use it as
a checklist to make sure you remembered to follow every step in the
proper order.
Lynn
proper order.
Lynn
--- In vantage@yahoogroups.com, Mark Wagner <mjfw2003@...> wrote:
> Thanks Lynn, I tried that but will look at it again to see if I
missed a step!
> --- On Tue, 10/28/08, Lynn <lynn.khalife@...> wrote:
> From: Lynn <lynn.khalife@...>
> Subject: [Vantage] Re: Shipment Entry Tracking Number on Invoice
> To: vantage@yahoogroups.com
> Date: Tuesday, October 28, 2008, 10:21 AM
> Did you remember to add a New Relationship to your Data Definition?
> The field PackNum doesn't appear to be in the InvcHead table in
> V8.03, but you could build this new relationship:
> InvcDtl.Company = ShipHead.Company
> InvcDtl.PackNum = ShipHead.PackNum
> Then ShipHead.TrackingNu mber should be available for use in your
CR
> Invoice form.
> Lynn
> --- In vantage@yahoogroups .com, Mark Wagner <mjfw2003@ .> wrote:
> > Trying to add the tracking number from the customer shipment
entry
> to the invoice. Have added the ShipHead to the data definition but
> can not get it to pull in. I'm sure its something simple I'm
missing
> but any help would be appreciated!
