Shop Warning Question - 8.03.4XX
I'm not sure why your shop tracker isn't working. I'm pretty sure the only
thing you have to do is check the "Report in Shop Tracker" checkbox in the
shop warning maintenance screen. I don't have any more information on that.
We are running on 8.03.403D and everything is working fine. As far as
emailing goes, I know that there are several places you have to enter your
smtp server name and default email address in order for it to work. There
is a place in company maintenance, and then I know there is also a place in
the mfgsys.config file that has to be updated. I don't have all the
information on this one, but I know it took us a while to get it working.
Then, in order for the emails to send, you have to run the "Global
Alerts/Email Process" that is in Systems Management>Utilities. It is
similar to what has to be done in order to email from BAMs also. Hope this
helps.
Daniel
_____
melissa hietala
Sent: Tuesday, July 29, 2008 5:47 PM
Subject: Re: [Vantage] Shop Warning Question - 8.03.4XX
Thanks for your response Daniel. I followed the instructions below and I was
able to get the warning message to display when I made the transaction.
However, the warning message still is not reported in the "shop tracker", I
also setup an e-mail alert to be sent out as well, and this action wasn't
performed either. Would you happen to have any info on these topics?
Thanks again,
Dustin Biniek
UMC, Inc.
DustinB@ultramc. <mailto:DustinB%40ultramc.com> com
----- Original Message ----
From: Daniel Laidig <daniellaidig@ <mailto:daniellaidig%40laidig.com>
laidig.com>
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com; melissa
hietala <kevmel822@yahoo. <mailto:kevmel822%40yahoo.com> com>
Sent: Tuesday, July 29, 2008 2:44:35 PM
Subject: RE: [Vantage] Shop Warning Question - 8.03.4XX
Try this.
MES Shop Warning Operation Over Qty Not Reporting
PAGE NUMBER: 23961MPS
PROBLEM DESCRIPTION: The shop warning 70 operation is over quantity is not
giving a warning in mes when you are reporting a over quantity operation.
RESPONSE:
The warnings will only show up if the Following conditions are met.
1) In Job entry, in the Job panel there is a Production Yield section with a
checkbox. It must be checked as true.
2) In Job entry go to Job Details tab / Operations / Detail. Right click in
the operations field and click ?Open with?? then Operation entry.
3) At the Operation maintenance in Detail tab. In the production yield
section click (as true) the Create shop warning and send shop warning alert
checkboxes.
After following these steps the warning will show up as expected.
Daniel
_____
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of
melissa hietala
Sent: Tuesday, July 29, 2008 2:26 PM
To: vantage@yahoogroups .com
Subject: [Vantage] Shop Warning Question - 8.03.4XX
I have a question related to shop warnings. I am looking to have two of the
system shop warnings to be displayed in the shop tracker when their
conditions are met. The two shop warnings that I need to have displayed are:
1) Code 70: Operation is Over Quantity.
2) Code 60: Operation was Completed Under Quantity.
To have these shop warnings display in shop tracker I did 3 things:
1) Went to system mgmt - company maintenance- company. I then verified that
the "Use Shop Warnings" box was checked. (I know that this is working
because there are other warning messages that are being displayed in shop
tracker)
2) Went to job mgmt - setup - operation. I then verified that the "Create
Shop Warning" and the "Send Shop Warning Alert" boxs were both checked.
3) Went to job mgmt - setup - shop warning. I then verified that the
"Report in Shop Tracker" boxs were checked for both "operation is over
quantity" and "operation was completed under quantity"
I believe that this is all that needed to be done so I ran a few tests but
unfortunately the warnings still don't display in the shop tracker. Is
there a step that I am missing here?
Any input would be greatly appeciated and thanks in advance for your help!
Dustin Biniek
UMC, Inc.
DustinB@ultramc. <mailto:DustinB% 40ultramc. com> com
I have a question related to shop warnings. I am looking to have two of the system shop warnings to be displayed in the shop tracker when their conditions are met. The two shop warnings that I need to have displayed are:
1) Code 70: Operation is Over Quantity.Â
1) Went to system mgmt - company maintenance-company. I then verified that the "Use Shop Warnings" box was checked. (I know that this is working because there are other warning messages that are being displayed in shop tracker)
2) Went to job mgmt - setup - operation. I then verified that the "Create Shop Warning" and the "Send Shop Warning Alert" boxs were both checked.
3) Went to job mgmt - setup - shop warning. I then verified that the "Report in Shop Tracker" boxs were checked for both "operation is over quantity" and "operation was completed under quantity"
I believe that this is all that needed to be done so I ran a few tests but unfortunately the warnings still don't display in the shop tracker. Is there a step that I am missing here?
 Dustin Biniek
UMC, Inc.
DustinB@...
Try this.
RESPONSE:
checkboxes.
Daniel
_____
melissa hietala
tracker)
Dustin Biniek
UMC, Inc.
Thanks for your response Daniel. I followed the instructions below and I was able to get the warning message to display when I made the transaction. However, the warning message still is not reported in the "shop tracker", I also setup an e-mail alert to be sent out as well, and this action wasn't performed either. Would you happen to have any info on these topics?
Thanks again,
Â
Dustin Biniek
UMC, Inc.
DustinB@...
To: vantage@yahoogroups.com; melissa hietala <kevmel822@...>
Try this.
RESPONSE:
checkboxes.
Daniel
_____
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of
melissa hietala
tracker)
Dustin Biniek
UMC, Inc.
You don't say which specific 4XX version you are running.
If it is any of the 404's, you might want to wait until you move to 405 as we are finding much of this (along with Yield Qty Recalc) work very unreliably - and actually (re Yield Qty Recalc) in clear violation of what the documentation professes it should do.
404 was/is the release from "the opposite of heaven" :)
With the number of bugs it introduced (which we began discovering the day of installation), there is absolutely no way it was tested by Epicor prior to release.
It easily has cost us $100,000 in lost productivity and delayed shipments.
We are now THROUGHLY testing 405 before install and, so far, it is an improvement... I will NEVER trust Epicor on software quality again.
The 7/24 email "Recap - What Epicor can do to address the 8.XX frustrations" is an absolute joke (and an INSULT if you have a brain)...
It is 'spin control' pure and simple as Epicor has a MOUNTAIN of Cases 8.x must have resulted in.
(We need to tell them AGAIN? They are spending time and money to 'reach out'?! Bull: HIRE A SUFFICIENT NUMBER OF COMPETENT, EXPERIENCED (IN MANUFACTURING) PROGRAMMERS AND PROGRAM MANAGERS.)
Responsible Deeds (and for a long long LONG time) will heal the mistrust...
There words mean nothing to my customers (and are a further waste of my time).
Date: Tuesday, July 29, 2008, 2:25 PM
1) Went to system mgmt - company maintenance- company. I then verified that the "Use Shop Warnings" box was checked. (I know that this is working because there are other warning messages that are being displayed in shop tracker)
 Dustin Biniek
UMC, Inc.
DustinB@ultramc. com
