rwhalebelly
(Richard Whalebelly)
1
We are on Kinetic 2021.1.17 and have an issue with a particular part not batching correctly.
So I restored the DB to pilot and to make testing quicker used DMT to untick Process MRP for only a couple of parts.
When looking at the log file I was surprised to see it is still processing every part.
Is this correct or do I need to change something other than the process MRP tick box under Part>Site
Regards
Richard
Rick_Bird
(Rick Bird)
2
Make sure âGenerate PO Suggestionsâ is disabled too. The MRP Process runs both Job and PO Suggestions.
rwhalebelly
3
Thanks, Rick I will try that.
A lot of the parts are manufactured but have PO suggestions ticked but greyed out.
I will report back.
Regards
Richard
rwhalebelly
4
Hi Rick
You were right it was PO suggestions even if the part is a manufactured part.
You need to untick both. To untick PO suggestions it has to be set to a purchased part first and then set back to manufactured.
Regards
Richard
