Solution tags for anything that can be included in a built solution
I would like to request an expansion of the “Directive group” feature that currently exists in the BPM system. I would call it a “Solution tags” and include anything that can in included in a solution build. I would also request it to be a system that allows more than one tag to be attached to it, since I may have something that is used in more than one place, but both solutions need it, I would like it included in both. Then when building a solution, a search that finds all elements (not jut all of the same type, ALL) and allows you to attach them to the solution would be ideal. This way, you can add whatever items you are making, (baq’s, dashboards, customizations, bpms, etc.) with a tag to this group, and then when you need to build the solution, you can build it with one search without forgetting anything.
