SSRS Error
I’m trying to add fields to the Bill Of Lading. I’ve added the additional fields in the report data definition and made sure they are not excluded.
="Select
T3.AddtlShipContactName_c,
T3.AddtlShipPhoneNum_c,
T3.AddtlShipEmail_c,
T3.AddtlShipAddInfo1_c,
T3.AddtlShipAddInfo2_c
from ShipHead_" + Parameters!TableGuid.Value + " T1
inner join Shipdtl_" + Parameters!TableGuid.Value + " T2 ON T1.Company = T2.Company AND T1.PackNum = T2.PackNum
inner join orderhed_" + Parameters!TableGuid.Value + " T3 ON T2.company = T3.Company AND T2.OrderNum = T3.OrderNum
When I try to upload it I get this error.
TxtShipToAddress2 is the name of the container text box. I haven’t gotten this error before; I really don’t know what is going on. Any help is appreciated.
That error is coming from the textbox’s data context. Say for example if it’s in a matrix, the matrix will have a dataset selection, and that’s the default data context that objects in the matrix will read from.
If the textbox is in an aggregated part of the data scope, like the customer name if there is a subgroup returning all the customer’s orders, the textbox’s value expression would need to do something like First(dataset.customername) because it may see many rows and a textbox can only display a scalar value.
If the referenced field is in a dataset that the textbox doesn’t have default access to, one of the lookup functions seem like a next step, and consider if it’ll need to do some kind of aggregate handling like first() or sum() etc.
https://www.mssqltips.com/sqlservertip/2141/sql-server-reporting-services-lookup-lookupset-and-multilookup-functions/
Is there a reason you created a new Dataset in your RDL vs adding the fields to the existing BOL dataset?
What did you use for a Data Source of your added Dataset?
Also, just doublechecking, but ShipHead above should be Shiphead (lowercase h) and orderhed should be OrderHed (to match the tables in your RDD).
What is the actual expression of the fields you’re adding vs existing? When I get this error it’s because the existing ones have like a FIRST() type syntax and mine does not.
Well, it is a little complicated the way you are trying it but will try to explain myself here.
If you added the fields to an existing table on the Data Definition, you just need to modify the query within the BOL dataset (the one the epicor report is using already), then you add them on the Fields list within that dataset.
You can do what you are trying - adding a dataset specific for OrderHed table, but then you need to use an aggregate function (First, Max, or a good one for these situations, LOOKUP).
With LOOKUP, you can build an expression where you will link the main dataset used on the report table, to get one specific record from the OrderHed dataset.
I would only use LOOKUP when strictly necessary, as even though I know how to make them work, I am unsure if it has any kind of performance impact, as it should be calculating this at runtime.
Hope this helps, and happy to explain in more detail if required.
Ms. @tmayfield: did you add a relationship from BOLDtl to OrderHed? I do not see that relationship in your screen shot?
DaveO
So, I got it fixed thanks to all of your comments.
I changed the expression for the value from:
=Fields!AddtlShipPhoneNum_c.Value
to
=First(Fields!AddtlShipPhoneNum_c.Value, “BOL”)
The SSRS loads now, but when I try to print the report, I get a dataset error.
When I test the connection within the RDL its successful.
I’ve taken the SQL statement in the expression, removed the parameters and run it in directly in SQL it ran fine. Anything I else I can look at?
Tammy, are you on premise?
Yes.
There should be a log on your SSRS server that shows you the detailed part of this and includes the fields that the query in your RDL is trying to select, that don’t exist in the table that’s being formed from your RDD— which is probably why this is failing.
Something like this: C:\Program Files\Microsoft SQL Server\MSRSXX.MSSQLSERVER\Reporting Services\LogFiles…
If you can find the log files you can poke around at them, copy them to a different location to inspect them. There’s like 4 types of logs so you’ll have to find the right one, but open up each one accoridng to the relevant time stamp on them, like generate your error then go search the logs quick.
Ctrl + F “BOL” and that should get you to the error in the log and then you can find the rest of the error abotu a field that doesn’t exist. They are SQL errors more or less.
Your BOL dataset is the issue.
Run the report
Set the archive to a day (to get a Table guid and for the tables to stick around for a bit)
open the rpt in Report Builder
run the report in Report Builder with the Table guid (this saves time of rerunning from Epicor)
You can even test that sql out as well if you want.
@tmayfield, not saying you have to, but would you care to share what log file you found it in or a little more detail in case someone else stumbles on this thread?
I found the file in:
C:\Program Files\Microsoft SQL Server Reporting Services\SSRS\LogFiles
Once I took out the OTSOrderNum it ran. But it doesn’t make a lot of sense as I’m joining on ShipHead to OrderHed and ShipHead has OTSOrderNum in it.
FROM BOLHead_" + Parameters!TableGuid.Value + " T1
LEFT OUTER JOIN BOLDetail_" + Parameters!TableGuid.Value + " T2 ON T1.Company = T2.Company AND T1.BOLNum = T2.BOLNum
LEFT OUTER JOIN ShipHead_" + Parameters!TableGuid.Value + " T3 ON T2.Company = T3.Company AND T2.BOLNum = T3.BOLNum AND T2.BOLLine = T3.BOLLine
LEFT OUTER JOIN Customer_" + Parameters!TableGuid.Value + " T4 ON T3.Company = T4.Company AND T3.CustNum = T4.CustNum
LEFT OUTER JOIN OrderHed_" + Parameters!TableGuid.Value + " T5 ON T3.Company = T5.Company AND T3.OTSOrderNum = T5.OrderNum
