THANK YOU! I remember seeing that when Ben was installing our software.
Sue
Sent: Monday, October 20, 2003 3:28 PM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Terminal Server access to database using local accounts
I can't believe my fingers were that far off .VTG = .MFG
Cliff Drumeller
Information Technology Manager
Mass Precision Sheetmetal
408 954-0200 ex 217
Sent: Monday, October 20, 2003 2:28 PM
accounts
Interesting that everyone refers to this *.vtg file which I haven’t found
yet. We are just running TS, no Citrix. Where is the *.vtg file(s) located
… I cannot find it on either server.
Thank you,
Sue
Sent: Monday, October 20, 2003 1:43 PM
accounts
We have been running Citrix with Terminal Server since Vantage 3.
I definitely would (and have) install Progress locally on the Terminal
Server, as this reduces a lot of network traffic from the Terminal
server to the Vantage server.
Before Vantage 6, I set the “TempDirectory†equal to blank in the
*.vtg file, and used “net use v: \\servername\epicor
<file:///\\servername\epicor> /persistent:no†in the usrlogon.cmd file
on each Terminal Server. If the “TempDirectory†is set to blank in
the *.vtg file, then Vantage will create a temp directory in the
“Documents and Settings\username\temp†directory. With the
“persistent:no†option in the Vantage drive mapping, the drive is
re-created each time the user logs on.
However; there is a bug in the automatic creation of the temp directory
beginning with ver 6 of Vantage… If you set the “TempDirectory†to
blank, you can not print ANY Report Builder reports.
In fact, this is not just with Terminal Server, but even with a LAN
client, if you leave the TempDirectory blank, you cannot print Report
Builder Reports!
The only way around it was to have a drive-letter mapped work directory
for each user!!!
Britt Moelling
M&M Manufacturing
Sent: Thursday, October 16, 2003 8:53 AM
accounts
Sue,
You will need to modify your .vtg file to exclude the temporary folder
of C:
\vntg**** whatever version you are working on. Terminal server creates a
temporary folder for each user on C:\temp\username and all the Vantage
temporary files created go there. Refer to documentation posted on
Epicor’s
web support. If you have NT TS and Citrix, I would avoid installing the
complete version of Progress as suggested in the same Epicor’s
document.
Stick with the client installation first and if it works, leave it as
that.
Another issue I found is that for Vantage 6.0 installation, the same
folder
of \\server\epicor <file:///\\server\epicor> was used for both Vantage
4.0
and 6.0. I followed the rule that you do not share the same drive letter
for
each Vantage installation. I used M:\ for Vantage 4.0 and S:\ for
Vantage 6.
0. It seems that this was an issue in my TS. I had to recreate user
profiles
to solve this situation. Unsharing the drive M:\ was not good enough for
my
TS. Maybe, someone in the group could share whether they had the same
problem and what solution they have.
Currently, I have Vantage 5.1-Progress 9.1 C and Vantage 6.0-Progress 9.
1D
installed and working in my TS.
Mario Aguirre
Lakin General
Sent: Wednesday, October 15, 2003 5:32 PM
To: Vantage User Group
Subject: [Vantage] Terminal Server access to database using local
accounts
Do any of you use terminal server to access Vantage? If so, how do you
setup the users? We thought we needed to setup local users and log on
locally but naturally you don't have access to the network and thus lose
any connectivity to the database server. What am I missing here? Are you
supposed to access TS using your network account?
Sue
Yahoo! Groups Sponsor
< http://rd.yahoo.com/M=259395.3614674.4902533.1261774/D=egroupweb/S=1705
<http://rd.yahoo.com/M=259395.3614674.4902533.1261774/D=egroupweb/S=1705>
0071
83:HM/A=1524963/R=0/SIG=12o885gmo/*http:/hits.411web.com/cgi-bin/autored
ir?c
amp=556&lineid=3614674âˆ=egroupweb&pos=HM>
< http://us.adserver.yahoo.com/l?M=259395.3614674.4902533.1261774/D=egrou
<http://us.adserver.yahoo.com/l?M=259395.3614674.4902533.1261774/D=egrou>
pmai
l/S=:HM/A=1524963/rand=351614764>
have
and
http://groups.yahoo.com/group/vantage/files/. <http://groups.yahoo.com/group/vantage/files/>
<http://groups.yahoo.com/group/vantage/files/. <http://groups.yahoo.com/group/vantage/files/> > <
< http://groups.yahoo.com/group/vantage/files/
< http://groups.yahoo.com/group/vantage/messages
<http://groups.yahoo.com/group/vantage/messages> >
< http://groups.yahoo.com/group/vantage/links
<http://groups.yahoo.com/group/vantage/links> >
Your use of Yahoo! Groups is subject to the Yahoo!
< http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> >
Terms of Service.
007183:HM/A=1524963/R=0/SIG=12o885gmo/*http:/hits.411web.com/cgi-bin/aut
oredir?camp=556&lineid=3614674âˆ=egroupweb&pos=HM>
pmail/S=:HM/A=1524963/rand=696849903>
< http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > .
http://rd.yahoo.com/M=259395.3614674.4902533.1261774/D=egroupweb/S=170500718
3:HM/A=1524963/R=0/SIG=12o885gmo/*http:/hits.411web.com/cgi-bin/autoredir?ca
mp=556
<http://rd.yahoo.com/M=259395.3614674.4902533.1261774/D=egroupweb/S=17050071
83:HM/A=1524963/R=0/SIG=12o885gmo/*http:/hits.411web.com/cgi-bin/autoredir?c
amp=556&lineid=3614674âˆ=egroupweb&pos=HM> &lineid=3614674âˆ
=egroupweb&pos=HM>
http://us.adserver.yahoo.com/l?M=259395.3614674.4902533.1261774/D=egroupmail
/S=:HM/A=1524963/rand=988335467
<http://us.adserver.yahoo.com/l?M=259395.3614674.4902533.1261774/D=egroupmai
l/S=:HM/A=1524963/rand=988335467> >
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <
ADVERTISEMENT
<http://rd.yahoo.com/M=244522.3707890.4968055.1261774/D=egroupweb/S=17050071
83:HM/A=1595054/R=0/SIG=124ukap9t/*http://ashnin.com/clk/muryutaitakenattogy
o?YH=3707890&yhad=1595054> Click Here!
<http://us.adserver.yahoo.com/l?M=244522.3707890.4968055.1261774/D=egroupmai
l/S=:HM/A=1595054/rand=855401095>
<http://rd.yahoo.com/M=259395.3614674.4902533.1261774/D=egroupweb/S=1705007183:HM/A=1524963/R=0/SIG=12o885gmo/*http:/hits.411web.com/cgi-bin/autoredir?camp=556&lineid=3614674%e2%88%9d=egroupweb&pos=HM>
<http://us.adserver.yahoo.com/l?M=259395.3614674.4902533.1261774/D=egroupmail/S=:HM/A=1524963/rand=681916232>
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/. <http://groups.yahoo.com/group/vantage/files/>
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
Sue
Cliff Drumeller
408 954-0200 ex 217
accounts
Thank you,
Sue
accounts
Builder Reports!
for each user!!!
Britt Moelling
M&M Manufacturing
accounts
Sue,
of C:
Epicor’s
document.
that.
folder
4.0
for
Vantage 6.
profiles
my
1D
Mario Aguirre
Lakin General
accounts
Sue
0071
ir?c
pmai
have
and
Terms of Service.
mp=556
=egroupweb&pos=HM>
ADVERTISEMENT
