Terminal Server
We have a separate vantage server and another server running citrix /
terminal services
Frank Zeigafuse
Innovative Office Products
General Manager
Direct Phone: 610-559-6369
Email: fzeigafuse@...
Sent: Wednesday, January 26, 2005 10:34 AM
Subject: [Vantage] Terminal Server
For those of you using terminal server for your data collection
stations, are you running terminal server on your Vantage Server, or
are you running it on a separate server. Also, how big of a box are
you running it on & for how many clients?
Thanks.
Ryan Rindler
Norwood Tool Company
Yahoo! Groups Links
<www.LCDarms.com> -- Ergonomic mounting solutions for monitors and keyboards
This e-mail is from Innovative Office Products, Inc. but expresses the views of the sender and not necessarily the views of the company. The email and any files transmitted with it are confidential to the intended recipient at the e-mail address to which it has been addressed. It may not be disclosed or used by any other than that addressee, nor may it be copied in any way. If received in error, please delete and notify the sender via e-mail or sales@... quoting the name of the sender. Messages sent via this medium may be subject to delays, non-delivery and unauthorized alteration. This e-mail has been prepared using information believed by the author to be reliable and accurate. Unless expressly stated otherwise, this e-mail does not form part of a legally binding contract or agreement between recipient and Innovative Office Products, Inc.
Warning: Although Innovative Office Products, Inc. has taken reasonable precautions to ensure no viruses are present in this email, we cannot accept responsibility for any loss or damage arising from the use of this email or attachments. It is, therefore, your responsibility to scan attachments (if any).
I need direction in getting my clients connected through terminal
server. I have TS installed on the server and the client installed
on the workstation. When I attempt to connect the connection times
out. Perhaps it is the adding of the user to terminal server and
some type of permissions that are wrong. Can anyone give me some
tips please?
I would like to help you, I got a lot of help from this list when we were
trying to get Terminal server going last spring and then with Citrix last
month. However, Since we set TS up so long ago, it's difficult to remember
the exact steps we took. Once we got the server configured properly, the
user folders set up, the vantage command line correct, and then installed
the client, it seems that it was pretty straightforward at that point.
Connect to TS, pick the TS computer name, and log on. Are you attempting to
access from a local client or a remote client? Sometimes across our T1 at
the remote sites, they will g et a Timeout error, but usually if they try
again it will connect. It is much slower than connecting locally. Are you
able to connect locally?
We are trying to connect remotely. We also have a T-1. What do you mean am
I able connect locally? I can connect as the Administrator locally but that
seems to be it.
From: sarah.vareschi@... [mailto:sarah.vareschi@...]
Sent: Friday, January 05, 2001 8:50 AM
To: vantage@egroups.com
Subject: RE: [Vantage] Terminal Server
Have you tried installing the terminal server client onto a local client and
connect to the Terminal server via that connection?
seems to be it.
Yes and I can connect as Administrator but only as Administrator.
Sent: Friday, January 05, 2001 9:01 AM
seems to be it.
What happens when you try connecting via another client name/password
locally?
times out
Sent: Friday, January 05, 2001 9:07 AM
locally?
Do you have all the users set up on your terminal server, with their own
folder in the users folder?
Do you have all users set up on the main server?
all users on Main server yes... I don't understand or know how to set users
folders
Sent: Friday, January 05, 2001 9:13 AM
Sarah... I have my user Chrisd created in the users. How do you create TS
Profile? What other pertinent information is required?
I used a book called "Windows NT Terminal Server and Citrix MetaFrame"
published by "New Riders" and written by Ted Harwood. I would recommend this
to anyone setting up Terminal server for the first time.
Ron Newell
IT/MIS
Neon Products
1695 Sargent Ave.
Winnipeg, MB R3H 0C4
http://www.neon-products.com/
mailto:rnewell@...
This message is intended only for the use of the person(s) ("intended
recipient")
to whom it is addressed. It may contain information which is privileged and
confidential.
If you are not the intended recipient please contact the sender as soon as
possible.
Accordingly any dissemination, distribution, copying or other use of this
message or any
of its content by any person other than the Intended Recipient is strictly
prohibited. We
have taken every precaution to ensure that this message is virus free but
we can not be
responsible for any damage that may be caused by its content.
I was looking for the notes, but I can't seem to find the binder. Our
network administrator is on Vacation this week, I think he'd remember
exactly how to set it all up. When we create new users now, it's just a
matter of creating a folder for that user within the users folder and
putting a vntgwork folder in there. Then we create a user folder in the
profiles folder and just copy everything from another users profile.
We also had to go into the user on the main server and edit the user so that
is maps v to the epicor directly on logon. This step is not needed with
Citrix, but we needed it when we were connecting through terminal server
directly into Vantage.
Lois, It sounds like you may not have the server set to allow the clients
to log on locally. You should create a group and place all TS users in that
group and let that group log on locally. You set these permissions using
User Manager\Policies\User Rights. Then select Log On Locally and select
the group you created. If you are connecting from a different domain, you
will need to set trusts up between domains. Hope this was of some help.
Roy Bosworth
Senior Manager IT/MIS
Sent: Friday, January 05, 2001 6:08 AM
tips please?
Where is the User Manager you are referring to? All are in one domain.
Sent: Friday, January 05, 2001 10:12 AM
Roy Bosworth
tips please?
Start\Programs\Administrative Tools (Common)\User Manager
This is a very basic NT function for an administrator. If you have trouble
with this, see "windows_nt4@egroups.com". This is a very good user group
dealing with NT issues.
Roy Bosworth
Sent: Friday, January 05, 2001 8:15 AM
To: 'vantage@egroups.com'
Roy Bosworth
tips please?
Im sorry Roy I didn't know if you meant NT or Epicor. We are brand new to
Epicor and just getting started. Thanks.
Sent: Friday, January 05, 2001 10:32 AM
Roy Bosworth
Roy Bosworth
tips please?
No problem Lois...
Roy Bosworth
818-503-8100
Sent: Friday, January 05, 2001 8:22 AM
Roy Bosworth
Roy Bosworth
tips please?
Make sure you get MetaFrame's Citrix.... Makes things a lot easier to
manage...
Sent: Friday, January 05, 2001 9:08 AM
tips please?
to www.egroups.com, login and be sure to save your password, choose My
Groups, choose Vantage, then choose Files. If you save the password,
the link above will work the next time you try it.)
Is Citrix not expensive?
Sent: Friday, January 05, 2001 10:34 AM
manage...
tips please?
