Is the problem with crystal reports or report builder reports?
Crystal you need to do a verify database on each reports. Reports builder,
it will depend on how you have everything set up, but you may need to go
into your customer report links and update the paths and possibly go in thru
report builder and fix the connections and if any fields changed as well...
