THANKS! Error: Tried to call a method in an invalid procedure. (7
Thanks Vic!!
Sent: Wednesday, April 2, 2014 11:34 AM
Subject: RE: [Vantage] Error: Tried to call a method in an invalid procedure. (7224)
7224 usually has to do with network connectivity…. usually a quick "blip" or packet loss on your computer is enough to trigger a 7224 error.  If it's just you that this is happening to, try checking your patch cord, network card, etc.
In E9, there's also a User Setting for Network Compression.. others have talked about that in the past on this group.  Perhaps give that a try.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jacqueline Restivo
Sent: Wednesday, April 02, 2014 11:22 AM
Subject: [Vantage] Error: Tried to call a method in an invalid procedure. (7224)
I keep getting this pop-up error in Epicor 905.606A.
Happened when I was trying to view a Wip Reconcilliation Report for a job.
Not the first time i've gotten this.
I will reboot....again.
thanks
Error Detail
Stack Trace
at Progress.Open4GL.DynamicAPI.PersistentProc.validate()
at Progress.Open4GL.DynamicAPI.PersistentProc.runProcedure(String procedureName, ParameterSet parms, MetaSchema schema)
at Epicor.Mfg.Core.CallContext.CallContextPersistentProc.runProcedure(String procedureName, ParameterSet parameters, MetaSchema metaSchema)
at Epicor.Mfg.Core.CallContext.ProxyHelper.CallMethod(String methodName, ParameterSet parameters, MetaSchema metaSchema, BLConnectionPool connPool, Session connection, PersistentProc persistProc, CallContextDataSet callContextDataSet)
at Epicor.Mfg.Proxy.ReportMonitorImpl.GetRowsKeepIdleTime(String whereClauseSysRptLst, Int32 pageSize, Int32 absolutePage, Boolean& morePages)
at Epicor.Mfg.UI.Adapters.ReportMonitorAdapter.GetRowsKeepIdleTime(SearchOptions opts, Boolean& MorePages
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277 -- #ygrps-yiv-800286030yiv0481097277ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277ygrp-mkp #ygrps-yiv-800286030yiv0481097277hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277ygrp-mkp #ygrps-yiv-800286030yiv0481097277ads {
margin-bottom:10px;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277ygrp-mkp .ygrps-yiv-800286030yiv0481097277ad {
padding:0 0;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277ygrp-mkp .ygrps-yiv-800286030yiv0481097277ad p {
margin:0;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277ygrp-mkp .ygrps-yiv-800286030yiv0481097277ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277ygrp-sponsor #ygrps-yiv-800286030yiv0481097277ygrp-lc {
font-family:Arial;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277ygrp-sponsor #ygrps-yiv-800286030yiv0481097277ygrp-lc #ygrps-yiv-800286030yiv0481097277hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277ygrp-sponsor #ygrps-yiv-800286030yiv0481097277ygrp-lc .ygrps-yiv-800286030yiv0481097277ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277activity span {
font-weight:700;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277activity span span {
color:#ff7900;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277activity span .ygrps-yiv-800286030yiv0481097277underline {
text-decoration:underline;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 .ygrps-yiv-800286030yiv0481097277attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 .ygrps-yiv-800286030yiv0481097277attach div a {
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 .ygrps-yiv-800286030yiv0481097277attach img {
border:none;padding-right:5px;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 .ygrps-yiv-800286030yiv0481097277attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 .ygrps-yiv-800286030yiv0481097277attach label a {
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 .ygrps-yiv-800286030yiv0481097277bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 .ygrps-yiv-800286030yiv0481097277bold a {
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 dd.ygrps-yiv-800286030yiv0481097277last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 dd.ygrps-yiv-800286030yiv0481097277last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 dd.ygrps-yiv-800286030yiv0481097277last p span.ygrps-yiv-800286030yiv0481097277yshortcuts {
margin-right:0;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 div.ygrps-yiv-800286030yiv0481097277attach-table div div a {
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 div.ygrps-yiv-800286030yiv0481097277attach-table {
width:400px;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 div.ygrps-yiv-800286030yiv0481097277file-title a, #ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 div.ygrps-yiv-800286030yiv0481097277file-title a:active, #ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 div.ygrps-yiv-800286030yiv0481097277file-title a:hover, #ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 div.ygrps-yiv-800286030yiv0481097277file-title a:visited {
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 div.ygrps-yiv-800286030yiv0481097277photo-title a, #ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 div.ygrps-yiv-800286030yiv0481097277photo-title a:active, #ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 div.ygrps-yiv-800286030yiv0481097277photo-title a:hover, #ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 div.ygrps-yiv-800286030yiv0481097277photo-title a:visited {
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 div#ygrps-yiv-800286030yiv0481097277ygrp-mlmsg #ygrps-yiv-800286030yiv0481097277ygrp-msg p a span.ygrps-yiv-800286030yiv0481097277yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 .ygrps-yiv-800286030yiv0481097277green {
color:#628c2a;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 .ygrps-yiv-800286030yiv0481097277MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 o {
font-size:0;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277photos div {
float:left;width:72px;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277reco-category {
font-size:77%;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277reco-desc {
font-size:77%;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 .ygrps-yiv-800286030yiv0481097277replbq {
margin:4px;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277ygrp-mlmsg select, #ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 input, #ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277ygrp-mlmsg pre, #ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 code {
font:115% monospace;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277ygrp-mlmsg #ygrps-yiv-800286030yiv0481097277logo {
padding-bottom:10px;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277ygrp-msg p#ygrps-yiv-800286030yiv0481097277attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277ygrp-reco #ygrps-yiv-800286030yiv0481097277reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277ygrp-sponsor #ygrps-yiv-800286030yiv0481097277ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277ygrp-sponsor #ygrps-yiv-800286030yiv0481097277ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277ygrp-sponsor #ygrps-yiv-800286030yiv0481097277ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277ygrp-text {
font-family:Georgia;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277ygrp-text tt {
font-size:120%;}
#ygrps-yiv-800286030 #ygrps-yiv-800286030yiv0481097277 #ygrps-yiv-800286030yiv0481097277ygrp-vital ul li:last-child {
border-right:none !important;}
thanks
Error Detail
Stack Trace
7224 usually has to do with network connectivity…. usually a quick "blip" or packet loss on your computer is enough to trigger a 7224 error. If it's just you that this is happening to, try checking your patch cord, network card, etc.Â
thanks
Error Detail
Stack Trace
