Aaron,
all Changes EPICOR are not tracked Automatically, I assume because it would
grow the database pretty fast. Anyhow, you have to create an BAM and choose the
fields you want to monitor then check of create log.
Ie. JobHead/ bring in available fields that
you want then action create log. This will enable the system to create a log
file every time something is changed and store it in the job head log
file.
We bring over everything in JOb head, nothing happens in a job with out some trace
—In vantage@yahoogroups.com, <aarondaane@…> wrote:Is there any way to track scheduling changes to jobs? For instance, if a job qty is changed or moved up in the schedule, is there a way to track those changes? I tried using the change log in the job entry/tracker screen, but it doesn't show much.Thanks to all.Aaron Daane
