Trouble with bpmemail.p
Thanks I did find it in mfgwrk803 along with the SMTP log.
But, curiously, there are no entries since Feb 16, 2012 when it failed on some error. Before that, there were entries almost ever few minutes (129MB log file)
--- In vantage@yahoogroups.com, "Kevin Simon" <simstrak@...> wrote:
> Your BPM Action Log is set when you first start the BPM Action Process.
> This is typically done only once, and is assigned to a schedule.
> You can find where it's at by opening up your system agent, finding your
> start up task, finding where the BPM Action Process is, then clicking the
> Actions to view the task parameters. That will show you where it's at in
> your installation.
> If I remember correctly, the default for this is not, for some reason, in
> the server/logs area. Typically when I'm working with my clients, I change
> it over, so that action log is the same place the other log files are. I
> got tired of going through the above process because I could never remember
> where the default location was.
> Kevin Simon
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> carl.heeder
> Sent: Friday, March 30, 2012 8:38 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: trouble with bpmemail.p
> Where can I find the BPM action log? Must be on the server somewhere?
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Kevin
> Simon" <simstrak@> wrote:
> > Have you checked the BPM Action log? That will let you know whether the
> > email made it out of Epicor, and whether there's more of an email relaying
> > issue.
> > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Behalf Of
> > carl.heeder
> > Sent: Thursday, March 29, 2012 6:24 PM
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > Subject: [Vantage] trouble with bpmemail.p
> > I've used this routine in the past to compose and send an email from
> within
> > a BPM. In fact, it is installed in an active BPM and is working quite
> well.
> > I've tried to copy and modify the BPM code to compose emails for a
> different
> > BO but this routine will not fire the bpmemail routine or it doesn't
> > execute. I can trace that it is doing everything to prep the message but
> the
> > email doesn't get sent. Iv;e even added a normal "action" email in the
> same
> > BPM and it sends OK
> > Nothing shows up in the server logs.
> > Anybody got some suggestions or tips for me?
I've used this routine in the past to compose and send an email from within a BPM. In fact, it is installed in an active BPM and is working quite well.
I've tried to copy and modify the BPM code to compose emails for a different BO but this routine will not fire the bpmemail routine or it doesn't execute. I can trace that it is doing everything to prep the message but the email doesn't get sent. Iv;e even added a normal "action" email in the same BPM and it sends OK
issue.
carl.heeder
BPM and it sends OK
You could try wrapping the code in this, if there is an issue in the code it will get written to this file. Also check Jose's site... http://www.usdoingstuff.com/2011/06/08/writing-to-a-file-from-progress-abl4gl/
Output To 'C:\debug.txt'.
Output close.
Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have already linked your email address to a yahoo id to enable access. )
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.%c2%a0
> issue.
> carl.heeder
> BPM and it sends OK
It'll be in your \EpicorData\ folder. Filled with 'Completed' and 'Processing' messages, and then stuffed in there it should show PIDs when the BPMs fire.
We don't have all that many, so I've made it so that all the BPMs log to the server log at the entry and exit of the BPM.
> > issue.
> > carl.heeder
> > BPM and it sends OK
your installation.
Kevin Simon
carl.heeder
> issue.
Behalf Of
> carl.heeder
within
well.
different
the
same
> BPM and it sends OK
