Trunc/erasing records from a UD table
>> It had something to do with allocation of space.
>> Any thoughts on Truncate vs delete?
I think you are correct about simple deletes - allocations remain.
I don't routinely use truncate, usually just during maintenance:
proutil mfgsys -C truncate bi
This article has some of the highlights:
http://knowledgebase.progress.com/articles/Article/20256
--- In vantage@yahoogroups.com, "cathyattechnologicsys" <cathy@...> wrote:
> I worked with Oracle Databases and was told that if you want to empty a table, it was better to use the Truncate rather than the Delete command.
> --- In vantage@yahoogroups.com, "Vic Drecchio" <vic.drecchio@> wrote:
> > Squirrel. DELETE from UD01
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> > jim_chance
> > Sent: Thursday, August 22, 2013 5:36 PM
> > Subject: [Vantage] Trunc/erasing records from a UD table
> > Does anyone know how to trunc/erase all records from a UD table for
> > Progress?
> > I have 2 tables that i want to delete all records from. DB is Progress.
Does anyone know how to trunc/erase all records from a UD table for Progress?
Do you have DMT?
Marco Vissuet
Systems Engineer
Pacific Contours Corporation
Cell (619)507-2311
Anaheim Office (714) 693-1260
San Diego Office (619)670-3900
Fax (714) 693-1252
mvissuet@...<mailto:marcov@...>
http://www.pacificcontours.com/
"The information contained herein may be subject to the International Traffic in Arms Regulations (ITAR) Warning: - This document contains data whose export is restricted by the Arms Export Control Act (Title 22, U.S.C., Sec 2751, et seq.) as amended, or the Export Administration Act (Title 50, U.S.C., App 2401 et seq.) as amended. Violations of these export laws are subject to severe criminal and civil penalties. Disseminate in accordance with provisions of DoD Directive 5230.25.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of jim_chance
Sent: Thursday, August 22, 2013 2:36 PM
__________ Information from ESET NOD32 Antivirus, version of virus signature database 8718 (20130822) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
What version are you on?
If you are on 9.05 or higher... do a data directive on the vendor table or on any table....
For last ttvendor no-lock:
For each ud01.
If avail ud01 then do:
Delete ud01.
End.
End.
End.
Marco Vissuet
Systems Engineer
Cell (619)507-2311
Fax (714) 693-1252
http://www.eset.com
Here is a quick and dirty option I've used with Progress.
Requires MS Access & temporary modification of the ODBC system DSN.
1 - change the ODBC default isolation level from "Read Uncomitted" to blank (this allows full access - so read,write & locks records)
2 - then in Access build a simple delete query on the UD table
Cautions:
- make a backup first
- there is no undo
- change the ODBC isolation level back when you are done
jim_chance
Progress?
> jim_chance
> Progress?
