UK Plastic Tax
Hello all,
We’re looking into how we’re going to implement the upcoming UK Plastic Tax. The issue that we’ve come across is that we’re wanting to incorporate this into the cost of our stock as it comes in (the tax is £200 per tonne of plastic).
We currently use Container Landed Cost Entry to disburse container freight and duty against the incoming stock. With the new tax there’s going to be a mixture of lines that need the tax adding and lines that don’t on each container.
We’ve done some initial checks but can’t see any way of doing this without building something custom.
Is there any standard functionality in Epicor that we’ve missed that might work in this scenario, or are we going to need to go down the customisation route?
There is a field called “Material Burden Rate” in Part Entry. You can try using this.
Vinay Kamboj
