found the answer. Not a great one, but I’ll stop banging my head trying to solve it.
Greg
Sent: Thursday, March 05, 2015 6:47 PM
Subject: [Vantage] RE: Updateable BAQ ttResults - schema error
sorry, 9.05.702A
Sent: Thursday, March 05, 2015 3:35 PM
What version and DB? In E10 I would probably be going to the Admin Console and doing the bit that updates the DB schema info like when you add a UD table. Had to do that too when I updated from 10.0.700.1 to 700.4. Don’t recall the steps or what it is called but that might be worth investigating – along with a good full backup.
-Todd C.
Sent: Thursday, March 05, 2015 2:15 PM
Subject: [Vantage] Updateable BAQ ttResults - schema error
Can someone tell me what this errors means? I have added every key of every table, used the standard PartCost BO to update and advanced bpm processing.
ERROR condition: Parameter number 2 (table ttResults) mismatch. Has 49 fields - client schema has 51 fields. (8030) (7211)
It happens as soon as I change a value.
Greg Payne
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible
for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately
delete the communication.
"This (document/presentation) may contain technical data as defined in the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10. Export of this material is restricted by the Arms Export Control Act (22 U.S.C. 2751 et seq.) and may not be exported
to foreign persons without prior approval form the U.S. Department of State."
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
