Updateable Dashboard - Deploy
I created a menu section just for testing.  Only I have security to see it, so I can test, but no one else can “accidently” use it.
Brenda
Sent: Tuesday, August 11, 2015 1:52 PM
Subject: [Vantage] Updateable Dashboard - Deploy
Is it possible to run an updateable dashboard without deploying the dashboard?  For example, a user has access to the dashboard menu and would like to update from the dashboard but does not have access to deploy or test it in order to update.  We didn’t want to add it to the main menu also for access reasons.  Is deploying it and adding it to the main menu the only option for updating the dashboard?
If a user has access to the dashboard menu, are they given access to test and deploy the dashboard also?
<!-- #ygrps-yiv-1712445492 _filtered #ygrps-yiv-1712445492 {font-family:Wingdings; panose-1:5 0 0 0 0 0 0 0 0 0;} _filtered #ygrps-yiv-1712445492 {font-family:Wingdings; panose-1:5 0 0 0 0 0 0 0 0 0;} _filtered #ygrps-yiv-1712445492 {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4;} _filtered #ygrps-yiv-1712445492 {font-family:Consolas; panose-1:2 11 6 9 2 2 4 3 2 4;} _filtered #ygrps-yiv-1712445492 {font-family:Verdana; panose-1:2 11 6 4 3 5 4 4 2 4;} #ygrps-yiv-1712445492 #ygrps-yiv-1712445492 p.ygrps-yiv-1712445492MsoNormal, #ygrps-yiv-1712445492 li.ygrps-yiv-1712445492MsoNormal, #ygrps-yiv-1712445492 div.ygrps-yiv-1712445492MsoNormal {margin:0in; margin-bottom:.0001pt; font-size:12.0pt; font-family:"Times New Roman", "serif";} #ygrps-yiv-1712445492 a:link, #ygrps-yiv-1712445492 span.ygrps-yiv-1712445492MsoHyperlink { color:blue; text-decoration:underline;} #ygrps-yiv-1712445492 a:visited, #ygrps-yiv-1712445492 span.ygrps-yiv-1712445492MsoHyperlinkFollowed { color:purple; text-decoration:underline;} #ygrps-yiv-1712445492 p {
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
font-family:“Times New Roman”, “serif”;}
#ygrps-yiv-1712445492 code
font-family:“Courier New”;}
#ygrps-yiv-1712445492 pre
margin:0in;
font-size:10.0pt;
#ygrps-yiv-1712445492 tt
#ygrps-yiv-1712445492 span.ygrps-yiv-1712445492cat
#ygrps-yiv-1712445492 span.ygrps-yiv-1712445492ct
#ygrps-yiv-1712445492 span.ygrps-yiv-1712445492HTMLPreformattedChar
font-family:Consolas;}
#ygrps-yiv-1712445492 p.ygrps-yiv-1712445492attach, #ygrps-yiv-1712445492 li.ygrps-yiv-1712445492attach, #ygrps-yiv-1712445492 div.ygrps-yiv-1712445492attach
margin-right:0in;
margin-left:0in;
font-size:9.0pt;
font-family:“Arial”, “sans-serif”;}
#ygrps-yiv-1712445492 p.ygrps-yiv-1712445492bold, #ygrps-yiv-1712445492 li.ygrps-yiv-1712445492bold, #ygrps-yiv-1712445492 div.ygrps-yiv-1712445492bold
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
font-weight:bold;}
#ygrps-yiv-1712445492 p.ygrps-yiv-1712445492green, #ygrps-yiv-1712445492 li.ygrps-yiv-1712445492green, #ygrps-yiv-1712445492 div.ygrps-yiv-1712445492green
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
color:#628C2A;}
#ygrps-yiv-1712445492 p.ygrps-yiv-1712445492replbq, #ygrps-yiv-1712445492 li.ygrps-yiv-1712445492replbq, #ygrps-yiv-1712445492 div.ygrps-yiv-1712445492replbq
margin:3.0pt;
font-size:12.0pt;
#ygrps-yiv-1712445492 p.ygrps-yiv-1712445492ad, #ygrps-yiv-1712445492 li.ygrps-yiv-1712445492ad, #ygrps-yiv-1712445492 div.ygrps-yiv-1712445492ad
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-1712445492 p.ygrps-yiv-1712445492underline, #ygrps-yiv-1712445492 li.ygrps-yiv-1712445492underline, #ygrps-yiv-1712445492 div.ygrps-yiv-1712445492underline
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-1712445492 span.ygrps-yiv-1712445492yshortcuts
#ygrps-yiv-1712445492 p.ygrps-yiv-1712445492ad1, #ygrps-yiv-1712445492 li.ygrps-yiv-1712445492ad1, #ygrps-yiv-1712445492 div.ygrps-yiv-1712445492ad1
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-1712445492 p.ygrps-yiv-1712445492ad2, #ygrps-yiv-1712445492 li.ygrps-yiv-1712445492ad2, #ygrps-yiv-1712445492 div.ygrps-yiv-1712445492ad2
margin-right:0in;
margin-bottom:7.5pt;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-1712445492 p.ygrps-yiv-1712445492underline1, #ygrps-yiv-1712445492 li.ygrps-yiv-1712445492underline1, #ygrps-yiv-1712445492 div.ygrps-yiv-1712445492underline1
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-1712445492 span.ygrps-yiv-1712445492yshortcuts1
font-family:“Verdana”, “sans-serif”;
font-weight:bold;}
#ygrps-yiv-1712445492 span.ygrps-yiv-1712445492yshortcuts2
font-weight:normal;}
#ygrps-yiv-1712445492 span.ygrps-yiv-1712445492EmailStyle36
font-family:“Calibri”, “sans-serif”;
color:#1F497D;}
#ygrps-yiv-1712445492 .ygrps-yiv-1712445492MsoChpDefault
font-size:10.0pt;}
margin:1.0in 1.0in 1.0in 1.0in;}
#ygrps-yiv-1712445492 div.ygrps-yiv-1712445492WordSection1
font-family:Symbol;}
font-family:Wingdings;}
#ygrps-yiv-1712445492 ol
{margin-bottom:0in;}
#ygrps-yiv-1712445492 ul
