If you are only using a handful of std table ud fields, just keep a list of what they are (and represent) in an excel sheet (or something equally handy).
If you are extensively using std table ud fields, you might want to consider using one or more of the UD tables available in Vantage to keep track of how you are using them. Create yourself a maintenance app to keep it current and you'll be set.
Mike Anstey <manstey@...> wrote:
As far as I know, you can change the name of the label on the data entry screen, but not the underlying name of the field.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Matt Caldwell
Sent: Tuesday, December 04, 2007 4:40 PM
Subject: [Vantage] User-Defined Fields
Is there a way to change the name of a user-defined field to something more useable( ShortName01 Ã "newfieldname")?
Or are we stuck with using ShortName01, Date01 andCharacter10?
Matt Caldwell
Technical Support Analyst
KERUSSO
P.O. Box 32
Berryville, AR 72616
Phone: 800-424-0943 Ext. 231
Fax: 870-423-3568
Web Site: http://www.kerusso.com <http://www.kerusso.com>
CONFIDENTIALITY STATEMENT:
This message, from Kerusso Inc., contains information
which is privileged and confidential and is solely for the use of
the intended recipient. If you are not the intended recipient, be
aware that any review, disclosure, copying, distribution, or use
of the contents of this message is strictly prohibited. If you have
received this in error, please destroy it and notify us immediately
at: 800-424-0943
Get easy, one-click access to your favorites. Make Yahoo! your homepage.
Matt Caldwell
KERUSSO
P.O. Box 32
Fax: 870-423-3568
at: 800-424-0943
