Vantage 305K Sales Kits
That is not the case. I am using kits all of the time. You do not set
them up as phantom but you do need to add a BOM. You classify the parts
as sales kits and and you state on the kit part number that you want the
components backflushed. You do not have the individual components set to
backflush. You will not have jobs for sales kits; the components are
added as line items to the sales order.
Kersten MacLennan
IT/ERP Analyst
Semrock, Inc.
3625 Buffalo Rd.,
Suite 6
Rochester, NY 14624
585-594-7009
585-594-7095 fax
kmaclennan@...
The Standard in Optical Filters for Biotech & Analytical Instrumentation
Hundreds of Thousands of Ion Beam Sputtered filters delivered -
extensive inventory now!
The information contained in this message and any attachments may be
privileged, confidential, and protected from disclosure. If the reader
of this message is not the intended recipient, or any agent responsible
for delivering this message to the intended recipient, you are hereby
notified that any dissemination, distribution, or copying of this
communication may be unlawful and therefore strictly prohibited. If you
received this message in error, please reply to the message and delete
it. Thank you
Of Robert Brown
Sent: Wednesday, February 13, 2008 12:16 PM
Subject: Re: [Vantage] Vantage 305K Sales Kits
I believe you're Kit Parts need to be set up as non-stock & phantom
("make direct") and you also need to run Order Wizard after sales entry
to generate a sales kit job (that will have no labor OPs).
I seem to recall the parts in each defined kit should also set to
backflush.
Lauren Hellings <LaurenH@... <mailto:LaurenH%40ericson.com> >
wrote:
We just started using Sales Kits recently and we are finding that when
the finished good line item on the order closes, the kit component lines
are still open. This is creating an issue with inventory, as there is no
transaction against the components of the kit. Are we missing a step
somewhere that needs to be done to close out the component lines?
Thank You,
Lauren L. Hellings
Systems Administrator
Ericson Manufacturing Co.
Looking for last minute shopping deals? Find them fast with Yahoo!
Search.
Thank You,
Lauren L. Hellings
The sales kit functionality isn't working quite the way it was intended
I don't think. Here are some of the issues that I have found with them.
Make sure that you set the Backflush Kit component flag to true on the
part form
You cannot have the component set as backflush
At order entry make sure that the line has the dates entered rather than
entering just on the release (this was a bug that has been fixed in the
latest version of .400
When creating RMA credit memos, the system will issue a credit for the
individual components, not the value of the kit. If the prices of the
components do not add up to the price of the kit, your credit will be
incorrect
There are others, and as I remember them I will continue to keep update
Kersten MacLennan
IT/ERP Analyst
Semrock, Inc.
3625 Buffalo Rd.,
Suite 6
Rochester, NY 14624
585-594-7009
585-594-7095 fax
kmaclennan@...
it. Thank you
Of Lauren Hellings
Sent: Wednesday, February 13, 2008 9:53 AM
Subject: [Vantage] Vantage 305K Sales Kits
Thank You,
Lauren L. Hellings
I believe you're Kit Parts need to be set up as non-stock & phantom ("make direct") and you also need to run Order Wizard after sales entry to generate a sales kit job (that will have no labor OPs).
I seem to recall the parts in each defined kit should also set to backflush.
Thank You,
Lauren L. Hellings
Looking for last minute shopping deals? Find them fast with Yahoo! Search.
