Vantage 5.0 ODBC instructions
Everything works ok with the ProControl the only thing you must do is to
uncheck the box "automatically start the database.." in the Progress
Explorer Tool
or you could disable the AdminService for PROGRESS 9.0B"
Sent: vrijdag 20 april 2001 14:16
Subject: Re: [Vantage] Vantage 5.0 ODBC instructions
This one seems to have missed the 5.0 bug list. This is serious for us, as
we rely heavily on Crystal Reports to get at the information we need.
Using ProControl in 5.0... Is there something you should UNDO in the Admin
Services to use ProControl instead? Or do you just set up Pro Control and
do it all from there and ignore the Progress Explorer Tool completely.
Troy Funte
Liberty Electronics
----- Original Message -----
Sent: Friday, April 20, 2001 6:39 AM
Subject: RE: [Vantage] Vantage 5.0 ODBC instructions
Troy and all eManufacturing users,
Be aware of the fact that Print previews FAIL to print when reports that
contain sub
report that connect to the vantage database,
(using the MERANT 3.60.32 BIT PROGRESS SQL92 v 9.1A ODBC driver PGPRO
915.DLL)
are used. The error message you will receive is "Error 599".
This also happens when compiling reports.
So in other words you can only use the fields from the DBF files or print
your reports from Crystal.
Or like in most cases keep on using the "MERANT 3.60.32 BIT PROGRESS
driver
IVPRO15.DLL".
But then you should use the ProControl to start the broker.
The 5.0 ODBC instruction is more or less the same as for 4.0. if you like
I
can post one.
Erik Weiffenbach
Sent: vrijdag 20 april 2001 9:00
To: Vantage
Subject: [Vantage] Vantage 5.0 ODBC instructions
I understand 5.0 comes with it's own ODBC drivers. Where are the
instructions for setting this up?
Troy Funte
Liberty Electronics
To access the Files Section of our Yahoo!Group for Report Builder and
Crystal Reports and other 'goodies', please go to:
http://groups.yahoo.com/group/vantage/files/. Note: You must have
already
linked your email address to a yahoo id to enable access.
Yahoo! Groups Sponsor
Click Here to Find Software Faster
http://groups.yahoo.com/group/vantage/files/. Note: You must have already
I understand 5.0 comes with it's own ODBC drivers. Where are the instructions for setting this up?
Troy Funte
Liberty Electronics
Check out the Epicor web site - or ERANet. There were no good instructions in the paperwork. We couldn't get the 3.6 ODBC drivers to work properly, and epicor even suggested that we stayed on Merant 3.5 ODBC, as complex reports ( 80% of ours are complex) would not work under the 3.6 drivers.
Regards,
David Sloan
IT Manager
Entech Integrated Technologies
To: Vantage
Sent: Friday, April 20, 2001 4:30 PM
Troy Funte
Liberty Electronics
OH great.
Sent: Friday, April 20, 2001 3:23 AM
Regards,
David Sloan
IT Manager
To: Vantage
Troy Funte
Liberty Electronics
To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please go to: http://groups.yahoo.com/group/vantage/files/. Note: You must have already linked your email address to a yahoo id to enable access.
contain sub
915.DLL)
Or like in most cases keep on using the "MERANT 3.60.32 BIT PROGRESS driver
IVPRO15.DLL".
The 5.0 ODBC instruction is more or less the same as for 4.0. if you like I
can post one.
Erik Weiffenbach
To: Vantage
Troy Funte
Liberty Electronics
This one seems to have missed the 5.0 bug list. This is serious for us, as we rely heavily on Crystal Reports to get at the information we need.
Using ProControl in 5.0... Is there something you should UNDO in the Admin Services to use ProControl instead? Or do you just set up Pro Control and do it all from there and ignore the Progress Explorer Tool completely.
Troy Funte
Liberty Electronics
contain sub
915.DLL)
IVPRO15.DLL".
can post one.
Erik Weiffenbach
To: Vantage
Troy Funte
Liberty Electronics
