Thank you for the helpful tips, I will make sure I check all of these items.
Kelly Potratz
Jose Ferrer <ferrerj@...> wrote:
Hello
Be sure your DNS (ODBCs in the test server) point to the correct DB server
Veryfy that following files have the correct server name (inside):
In folder <drive>\Epicor\mfgsys80\server\config
mfgsys.ini
mfgsys.pf (this files use the DSN)
mfgtest.pf
mfgtrain.pf
In folder <drive>\Epicor\mfgsys80\client\Config
default.mfgsys
test.mfgsys
train.mfgsys
Verify also file <drive>\oe100b\properties\ubroker.properties (usually not
have any server name)
In the client computers you should make a copy of your Client folder and
modify the config files as well
Change the properties in the vantage app icons (to point to you test client
folder) and the vantage admin icons (it has the server name)
If you have the application and the db server in the same box you can
disconect it from the network and test the application to verify everything
is working properly
Regards,
Jose Ferrer
Express yourself instantly with MSN Messenger! Download today it's FREE!
http://messenger.msn.click-url.com/go/onm00200471ave/direct/01/
Stay in the know. Pulse on the new Yahoo.com. Check it out.
Kelly Potratz
Hello
mfgsys.ini
mfgtest.pf
mfgtrain.pf
default.mfgsys
test.mfgsys
train.mfgsys
is working properly
Regards,
Jose Ferrer
>From: "kpotratz_05" <kpotratz_05@...>__________________________________________________________
>Reply-To: vantage@yahoogroups.com
>Subject: [Vantage] Vantage 8.0: Test Installation
>Date: Wed, 04 Oct 2006 15:33:20 -0000
>I have purchased a server to be used as a Vantage Test server. Are
>there any settings I need to change on the test server installation to
>make sure nothing interferes with the production installation. Or, can
>I leave everything default?
>Thanks in advance-
>Kelly Potratz
