We have the following settings:
Server File: c:\epicor\mfgsysdata
Client File: \\<VantageServer>\epicor\mfgsysdata
Client Program: \\<VantageServer>\epicor\mfgsys803\Server
They work for the Vantage 8 system at our other division (separate system) and they work in our training DB.
Epicor believes it has something to do with the DB conversion from V5 to V6 to V8. But, they have no solutions to offer.
Thanks for your feedback.
Scott
Scott
--- In vantage@yahoogroups.com, "bw2868bond" <bwalker@...> wrote:
> System Management -> Utilities -> System Agent
> Load your System Task Agent Client File Directory should be a UNC path to the MfgSysData share on your Vantage Server
> \\<VantageServer>\MfgSysData
> --- In vantage@yahoogroups.com, "sdzwieg" <sdzwieg@> wrote:
> > Greetings,
> > We are in the process of upgrading from Vantage 5.20.322 to 8.03.409C.
> > For some reason we are not able to print reports from any client installation of Vantage 8, only the main server. Something is pointing the print application to the local drive and not the server.
> > Error Detail
> > Could not find a part of the path 'c:\epicor\mfgsysdata\Reports\xxxxxx\Methods Master Report28206.TXT'.
> > Stack Trace
> > at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
> > at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy)
> > at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
> > at Epicor.Mfg.Lib.Report.EpiTextDocument..ctor(String filename, Int32 linesPerPage, Session currentSession)
> > at Epicor.Mfg.UI.App.SysMonitorEntry.Transaction.checkIfDocumentLoaded(String rptFile, Int32 maxLinesPerPage)
> > at Epicor.Mfg.UI.App.SysMonitorEntry.Transaction.previewTxtReport()
> > We have verified the System Agent directory settings with Epicor and they have not been able to provide a solution.
> > Any suggestions would be greatly appreciated.
> > Regards,
> > Scott Zwieg
> > IS Manager
> > IMS-Electrol
