The problem seems to occur only on reports that have to reference a .XLM
datasource when it goes to display it. The reports that generate just a
.TXT file run/view just fine. Anyone have any ideas?
Sent: Friday, August 03, 2012 9:13 AM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] New install of Vantage Server 8.03/Progress 10.1b -
Can't view reports
I may have spoke to soon. Most of the canned reports are now working but
I've got an error on the "scheduled shipments" reports that it gets to where
is says "retrieving data" and then an error pops up that says "Load failed"
and down in the detail it says "Inner Exception...The system cannot find the
path specified". Most of the other canned reports in Vantage are working
fine. Any ideas??
Thanks in advance!
Mike..
Mike Abell
Sent: Thursday, August 02, 2012 10:25 PM
Cc: vantage@yahoogroups.com
Subject: Re: [Vantage] New install of Vantage Server 8.03/Progress 10.1b -
Can't view reports
Thanks everyone, that did It. Working now
On Aug 2, 2012, at 4:42 PM, "Ned"
<TechnoBabbly@...<mailto:TechnoBabbly@...>> wrote:
A couple things that may help you find the answer...
1- Did you install with the same file paths as your original installation?
Meaning if it was in C:\Epicor\Mfgsys803 on your production server, is it in
C:\Epicor\Mfgsys803 on your test server?
2- Did you copy all your custom reports from Mfgsys803\reports\CustomReports
to the test server from the production server?
3- Did you update your systemtask agent with the correct file locations for
the MFGSYSDATA file location? It should be a UNC path to a shared folder
called MFGSYSDATA, and it will be different from your production server.
Make sure all 3 are using the new server paths.(I suspect this is the real
issue)
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf
Of flexial_ma
Sent: Thursday, August 02, 2012 4:43 PM
Subject: [Vantage] New install of Vantage Server 8.03/Progress 10.1b - Can't
view reports
I've created a development server to do testing with and everything is
working good except when we try to run a report we get an error that states
"Could not find part of a path C:\MfgsysData\Reports\mabell\yada yada yada".
I see on the actual Vantage server that this path/file it is looking for
exists but I think the report is actually looking on the "local machine's C
drive" for this path which doesn't exist. How do I "repoint" vantage to use
the server path to find the data versus the local machine path? Thanks in
advance!
Mike..
Can't view reports
fine. Any ideas??
Thanks in advance!
Mike..
Mike Abell
Can't view reports
issue)
Of flexial_ma
view reports
advance!
Mike..
