Vantage 8.03.4x Check printing hang up
Regarding 8.03.4x... We recently opened an incident with Epicor
Support whether Windows XP SP3 is supported. They replied that SP3
has known printing issues and SP2 is still the recommended version.
See the latest 8.03.400 Hardware and Configuration Sizing Guide dated
2/25/08.
--- In vantage@yahoogroups.com, Todd Caughey <caugheyt@...> wrote:
> I'll second this for other applications. We've had it several
times where accounting people (who typically print checks) also have
other applicaitons (like Sage Fixed Assets) that use a stripped down
version of Crystal as a report writer. Uninstalling the Vantage
client and re-installing and then applying the Crystal 8.5 related
patches on the Epicor site has always cleared this up for us. There
are also several Crystal related .dll files that you can try copying
from another PC where checks work (in particular CRPE32.dll) and see
if this helps but it may also break any other application's Crystal
reporting.
> -Todd C.
Behalf Of Winter, Patrick
> Sent: Tuesday, September 30, 2008 10:03 AM
> To: vantage@yahoogroups.com
> Subject: RE: RE: [Vantage] (6.0) Check printing hang up
> If it's a crystal form for printing checks have you verified the
form.
> Do you have any other applications on the PC that use crystal
reports?
> Patrick Winter
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On
Behalf
> Of Paul Lipham
> Sent: Tuesday, September 30, 2008 10:00 AM
> I think it may be a Windoz update issue, but Epicor support told me
it
> was not a Windoz issue too. However, they never told me what the
issue
> was, because they could not figure it out. Eventually I gave up and
we
> have just been living with it.
<mailto:vantage%40yahoogroups.com> ] On
> Behalf Of Geary, Stephanie
> Sent: Tuesday, September 30, 2008 9:55 AM
> Subject: RE: [Vantage] (6.0) Check printing hang up
> It started happening here when the computers started having
computers
> with new versions of Windows... but they swear it wasn't that...
> <mailto:vantage%40yahoogroups.com> <mailto:vantage%
40yahoogroups.com>]
> On Behalf
> Of Paul Lipham
> Sent: Tuesday, September 30, 2008 10:53 AM
> It was the same way with us. It just started happening one day. I
have
> even replaced the workstation with a new system and have seen the
same
> problem. At times it's not an issue. We did the black box with
Vantage
> support and sent them all kinds of information, but nothing was ever
> resolved. Not long after the check printing issue I had the same
problem
> with a lady that prints job travelers, so I do not think it is only
> related to printing checks.
40yahoogroups.com>
> On
> Behalf Of Chris Stover
> Sent: Tuesday, September 30, 2008 9:47 AM
40yahoogroups.com>
> The weird thing is, we have been on this level (and patch) for four
> years now and this problem has only just started to occur within the
> past 6 months. His computer is the only PC that prints checks and
it is
> a dedicated printer for checks, but he also has a network printer
that
> he prints to for everything else. It is just odd that it is now
> happening. At first I thought it was a hang with his username, but
then
> it started to happen when he would sign in using a different
username so
> now I am baffled.
> Chris Stover
> -----Original Message-----
40yahoogroups.com>
40yahoogroups.com>
40yahoogroups.com>]
> On Behalf
> Of Paul Lipham
> Sent: Tuesday, September 30, 2008 9:26 AM
40yahoogroups.com>
> It's a known problem with Vantage 6.XX as far as I know. We have
had the
> issue and continue to have it. We spent weeks on this with Vantage
> support, but to no avail.
> Basically if you print to two different printers Vantage/Progress
gets
> confused. If you only print to the checks printer it should not be
as
> bad, however this isn't possible for us.
> Before printing checks we have to exit Vantage, delete all the
vantage
> work files. C:\epicor\VntgWrk61\*.* then log back into Vantage and
the
> checks will print.
> Hope this helps!
> From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> [mailto:vantage@yahoogroups <mailto:vantage%
40yahoogroups.com> .com] On
> Behalf Of Edward F. Fox, Jr.
> Sent: Tuesday, September 30, 2008 9:01 AM
> To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> Used to happen to us all the time. Since upgrading to 8.03.4xx we
have
> not
> had the problem.
> Edward F. Fox, Jr., CPA
> Controller
> Maxson Automatic Machinery Company
> Phone 401-596-0162 Fax 401-596-1050
> www.maxsonautomatic.com
> _____
> .com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups
> .com<mailto:vantage%40yahoogroups.com>] On Behalf Of
> Chris Stover
> Sent: Tuesday, September 30, 2008 9:59 AM
> To: Vantage Group
> Subject: [Vantage] (6.0) Check printing hang up
> We have been having issues with our check printing wanting to hang
up as
> we go to actually print out the checks. We can call up the invoices
and
> list them out just find, but when we print it doesn't do anything.
At
> first I thought it was something with the username, but then I had
him
> switch to a different user name and it is still the same problem. We
> can get them to print if we do a mass delete, post the group, and
then
> restart the computer. I have tried different login ID's, different
> group ID's, but it is still the same problem. He has a new computer,
> but the problem was happening before that. I have gone through and
> deleted out the temp folder, and still a problem. My assumption is
that
> something is hung up within Vantage itself, and I have even
restarted
> the server.
> Has anyone seen anything like this? If you have, what did you do to
fix
> the hangup? I haven't done any upgrades in terms of patch levels and
> this is a fairly recent problem that has been popping up.
> Any help is great. Thanks.
> Chris Stover
We have been having issues with our check printing wanting to hang up as
we go to actually print out the checks. We can call up the invoices and
list them out just find, but when we print it doesn't do anything. At
first I thought it was something with the username, but then I had him
can get them to print if we do a mass delete, post the group, and then
deleted out the temp folder, and still a problem. My assumption is that
something is hung up within Vantage itself, and I have even restarted
the server.
Has anyone seen anything like this? If you have, what did you do to fix
Chris Stover
Used to happen to us all the time. Since upgrading to 8.03.4xx we have not
had the problem.
Controller
Phone 401-596-0162 a Fax 401-596-1050
_____
Chris Stover
To: Vantage Group
the server.
Chris Stover
It's a known problem with Vantage 6.XX as far as I know. We have had the issue and continue to have it. We spent weeks on this with Vantage support, but to no avail.
Basically if you print to two different printers Vantage/Progress gets confused. If you only print to the checks printer it should not be as bad, however this isn't possible for us.
Before printing checks we have to exit Vantage, delete all the vantage work files. C:\epicor\VntgWrk61\*.* then log back into Vantage and the checks will print.
Hope this helps!
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Edward F. Fox, Jr.
had the problem.
Controller
_____
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
Chris Stover
To: Vantage Group
the server.
Chris Stover
Some times it works and some times it doesn't... we have had this as
well and tried to get help from Epicor - we get stuck in the middle of
processing checks and then have to void a bunch of checks. Sometimes
it works and sometimes it doesn't
Of Paul Lipham
Sent: Tuesday, September 30, 2008 10:26 AM
checks will print.
Hope this helps!
not
had the problem.
Controller
_____
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>]
On Behalf Of
Chris Stover
To: Vantage Group
the server.
Chris Stover
This message has been processed via your triumphgroup.com e-mail
address.
past 6 months. His computer is the only PC that prints checks and it is
a dedicated printer for checks, but he also has a network printer that
happening. At first I thought it was a hang with his username, but then
it started to happen when he would sign in using a different username so
now I am baffled.
Chris Stover
Of Paul Lipham
checks will print.
Hope this helps!
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
not
had the problem.
Controller
_____
Chris Stover
To: Vantage Group
the server.
Chris Stover
It was the same way with us. It just started happening one day. I have even replaced the workstation with a new system and have seen the same problem. At times it's not an issue. We did the black box with Vantage support and sent them all kinds of information, but nothing was ever resolved. Not long after the check printing issue I had the same problem with a lady that prints job travelers, so I do not think it is only related to printing checks.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Chris Stover
now I am baffled.
Chris Stover
Of Paul Lipham
checks will print.
Hope this helps!
not
had the problem.
Controller
_____
Chris Stover
To: Vantage Group
the server.
Chris Stover
It started happening here when the computers started having computers
Of Paul Lipham
now I am baffled.
Chris Stover
On Behalf
Of Paul Lipham
checks will print.
Hope this helps!
not
had the problem.
Controller
_____
Chris Stover
To: Vantage Group
the server.
Chris Stover
address.
I think it may be a Windoz update issue, but Epicor support told me it was not a Windoz issue too. However, they never told me what the issue was, because they could not figure it out. Eventually I gave up and we have just been living with it.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Geary, Stephanie
Of Paul Lipham
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
now I am baffled.
Chris Stover
On Behalf
Of Paul Lipham
checks will print.
Hope this helps!
not
had the problem.
Controller
_____
Chris Stover
To: Vantage Group
the server.
Chris Stover
address.
If it's a crystal form for printing checks have you verified the form.
Do you have any other applications on the PC that use crystal reports?
Patrick Winter
Of Paul Lipham
On Behalf
Of Paul Lipham
On
now I am baffled.
Chris Stover
On Behalf
Of Paul Lipham
checks will print.
Hope this helps!
not
had the problem.
Controller
_____
Chris Stover
To: Vantage Group
the server.
Chris Stover
address.
This e-mail and any attachments may contain confidential and
privileged information. If you are not the intended recipient,
please notify the sender immediately by return e-mail, delete this
e-mail and destroy any copies. Any dissemination or use of this
information by a person other than the intended recipient is
unauthorized and may be illegal.
We have had the same issue ever since we upgaded to 6.1. It seems
to be related to any Crystal forms (invoices, travelers, quotes,
checks, etc). For us, closing Vantage and then logging back in
typically solves the problem. We have never been able to find a
solution either. Oddly enough, though, the problem seems worse on
HP Laserjet printers than other printers......
Adam Whipp
form.
reports?
> Patrick Winter
Behalf
> Of Paul Lipham
me it
issue
and we
computers
40yahoogroups.com>]
> On Behalf
> Of Paul Lipham
have
same
Vantage
ever
problem
40yahoogroups.com>
> On
40yahoogroups.com>
the
it is
that
then
username so
> now I am baffled.
> Chris Stover
40yahoogroups.com>
40yahoogroups.com>
40yahoogroups.com>]
> On Behalf
> Of Paul Lipham
40yahoogroups.com>
had the
gets
as
vantage
the
> checks will print.
> Hope this helps!
have
> not
> had the problem.
> Controller
> _____
> Chris Stover
> To: Vantage Group
up as
invoices and
At
him
We
then
computer,
that
restarted
> the server.
to fix
and
> Chris Stover
> address.
I'll second this for other applications. We've had it several times where accounting people (who typically print checks) also have other applicaitons (like Sage Fixed Assets) that use a stripped down version of Crystal as a report writer. Uninstalling the Vantage client and re-installing and then applying the Crystal 8.5 related patches on the Epicor site has always cleared this up for us. There are also several Crystal related .dll files that you can try copying from another PC where checks work (in particular CRPE32.dll) and see if this helps but it may also break any other application's Crystal reporting.
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Winter, Patrick
Patrick Winter
Of Paul Lipham
On Behalf
Of Paul Lipham
On
now I am baffled.
Chris Stover
On Behalf
Of Paul Lipham
checks will print.
Hope this helps!
not
had the problem.
Controller
_____
Chris Stover
To: Vantage Group
the server.
Chris Stover
address.
