We are on SQL.
The ratio of 3/1 is a good starting point. The ratio I'm using now is
almost 7/1 which is maybe 10% faster than 3/1. In our case, the
additional 10% counts.
--- In vantage@yahoogroups.com, "markewhittaker" <markewhittaker@...>
wrote:
>or
> Brad,
> I am curious as to what environment you are running on. Progress
> SQL, Windows or Unix. We have also been having long MRP runtimes(or
> at least I thought they were long until I read your post about 100have
> hours). We installed the 809 patch and had a talk with Epicor's VP
> of Development who recomended a 3/1 Scheduler/Processes ratio to
> start from. He said the improvements were more dramatic with SQL
> since it was slower to start, but we run Progress. We currently
> the database on Windows but plan to move it to our unix box soon.date
> Could you please specify what environment you run on and any other
> insight you have about tuning the performance?
> Thanks.
> --- In vantage@yahoogroups.com, "Brad Feazell" <Brad_feazell@>
> wrote:
> > There are two big changes to MRP in 809 that may make the upgrade
> > worthwhile depending on your needs.
> > 1) Major performance improvement. If you have server memory to
> spare,
> > you can experiment with the number of processors and schedulers
> which
> > are configurable on the Process MRP form - each requires an app
> > server. I have found that in our environment, 3 schedulers and 20
> > processors yeilds the fastest run time. The total runtime was
> reduced
> > from over 100 hours to less than 5 hours. We have a very large
> > database with lots of everything (orders, parts, jobs, resources,
> > etc.) so this was important to us.
> > 2) You can enable historical dates and set the schedule start
> into
> > the past. We did some superficial testing on this and it appears
> > work OK.On
> > --- In vantage@yahoogroups.com, "Chuck Andrews" <controller@>
> > wrote:
> > > We didn't license MRP, so I can't speak from first hand
> experience;
> > but I
> > > did notice a number of MRP fixes on the Release 9 change list.
> > > If you're not yet ready to install 8.00.809. you can at least
> > download the
> > > change document to see if it your problems were addressed.
> > > Chuck Andrews
> > > Iridium Industries, Inc.
> > > One Forge Road
> > > E. Stroudsburg, PA 18301
> > > 570-476-8800 Ext 14
> > > Controller@
> > > _____
> > > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]
> > Behalf Ofand
> > > gsc1161
> > > Sent: Wednesday, August 09, 2006 10:34 AM
> > > To: vantage@yahoogroups.com
> > > Subject: [Vantage] Vantage 8 MRP issues
> > > Has anyone else had, or is having issues with conversion data
> > > MRP? Things like incorrect quantity suggestions, balance goinglike
> > > negative, duplicate PO's, etc?
> > > If anyone is using MRP in 8.0 can you please reply? I would
> to
> > > know how many users are using MRP.
> > > Thanks in advance.
