Thanks for tip Justin. That worked and we are able to print the Crystal Reports.Â
Â
However, now the Bar Code Font will no longer print on the Job Travellers.
Â
Is there a fix for this as well?
Â
Thanks again,
Â
Kerry Travis
Sent: Friday, August 10, 2012 11:15:08 AM
Subject: [Vantage] Re: Vantage 803.408b crashes when printing using Windows 7
Â
Upgrade the crystal reports .net runtime file to a newer version.
Â
Â
Â
Thanks again,
Â
Kerry Travis
Â
--- In mailto:vantage%40yahoogroups.com, Kerry Travis <kerrytravis@...> wrote:
> Good morning all,
> Â
> Some folks here are having problems with Vantage crashing when printing the canned Crystal Reports.
> Â
> After a bit of investigation, it was determined that only those users who run Windows 7 are having the problems. Those of us with Windows XP do not have an issue.
> Â
> Has anyone run into this? Is there a fix? From what we got from Epicor, they are not fixing this as 803.408b was not intended to run on Windows 7.
> Â
> Any help would most certainly be appreciated.
> Â
> Thanks and best regards,
> Â
> Kerry Travis, CGA
> Controller
> International Name Plate Supplies Limited
