Vantage and barcodes
Take a look in the files section under Barcoding on this site. I have a doc up there that does the initial setup and setting the min char length to 1 is one of the settings.
Sent: Thursday, January 19, 2012 8:43 AM
Subject: RE: [Vantage] Re: Vantage and barcodes
I looked in the manual for this scanner (MOTOROLA SYMBOL LS2208) and I cannot find anything that sets that.
I am currently downloading a doc. From the website and hope to find that setting.
If anyone has a barcode that set that I would appreciate it.
Mike
From: mailto:vantage%40yahoogroups.com [mailto:mailto:vantage%40yahoogroups.com] On Behalf Of Steven Gotschall
Sent: Thursday, January 19, 2012 7:26 AM
To: mailto:vantage%40yahoogroups.com
Subject: Re: [Vantage] Re: Vantage and barcodes
By default, most scanners won't read a single character. This can be changed via the setup of the scanner. I think the logic is that a bar code with only one character must be a mistake.
From: Mike Carter <mailto:mcarter%40youngbergindustries.com<mailto:mcarter%40youngbergindustries.com>>
To: "mailto:vantage%40yahoogroups.com<mailto:vantage%40yahoogroups.com>" <mailto:vantage%40yahoogroups.com<mailto:vantage%40yahoogroups.com>>
Sent: Thursday, January 19, 2012 8:13 AM
Thank you
That solved that issue.
Now I have another problem with barcodes. The reader won't read the assembly barcode.
Is there a fix for that?
I scan the barcode and nothing shows up in the assembly area.
From: mailto:vantage%40yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:mailto:vantage%40yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of gmack110256
Sent: Wednesday, January 18, 2012 3:55 PM
To: mailto:vantage%40yahoogroups.com<mailto:vantage%40yahoogroups.com>
Subject: [Vantage] Re: Vantage and barcodes
We used the following code to get the Tab function to work:
"*"&{JobAsmbl.JobNum}&"$I"&"*"
the &"$I" is the code for the tab.
Gene
--- In mailto:vantage%40yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, Mike Carter <mcarter@...<mailto:mcarter@...<mailto:mcarter@...%3cmailto:mcarter@...>>> wrote:
> Thank you that worked great.
> Can anyone tell me how to remove the decimal point in the barcode?
> MES does not like the decimal points in the quantity.
> Thanks
> From: mailto:vantage%40yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:mailto:vantage%40yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of Gary Wilcox
> Sent: Wednesday, January 18, 2012 12:25 PM
> To: mailto:vantage%40yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> Subject: RE: [Vantage] Vantage and barcodes
> Mike,
> Check the manual for the barcode wands you are using. You should be able to
> program them to append a tab after the scan.
> Gary Wilcox
> Swiftcor Aerospace
> From: mailto:vantage%40yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:mailto:vantage%40yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of
> Mike Carter
> Sent: Wednesday, January 18, 2012 9:30 AM
> To: mailto:vantage%40yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> Subject: [Vantage] Vantage and barcodes
> We are starting to use barcodes in our shop and noticed that you still have
> to manually hit the tab key on the keyboard.
> Is there a code that could be introduced to the barcodes that will
> automatically tab for you?
> We are running Vantage 8.03.409C
> Thanks
> [cid:image001.png@...<mailto:image001.png%4001CCD5D4.7E924540>
> <mailto:image001.png%4001CCD5D4.7E924540> ]<mailto:[cid:image001.png@...%3cmailto:image001.png%4001CCD5D4.7E924540%3e%0b%3e%20%3cmailto:image001.png%4001CCD5D4.7E924540%3e%20]><mailto:[cid:image001.png@...%3cmailto:image001.png%4001CCD5D4.7E924540%3e%0b%3e%20%3cmailto:image001.png%4001CCD5D4.7E924540%3e%20]>
> Michael Carter
> I.T. Director
> 6863 Indy Drive.
> Belvidere, IL 61008
> Phone: 815-544-2177
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2012.0.1901 / Virus Database: 2109/4752 - Release Date: 01/18/12
We are starting to use barcodes in our shop and noticed that you still have to manually hit the tab key on the keyboard.
Is there a code that could be introduced to the barcodes that will automatically tab for you?
[cid:image001.png@01CCD5D4.7E924540]
Michael Carter
I.T. Director
6863 Indy Drive.
Belvidere, IL 61008
Phone: 815-544-2177
Mike,
Gary Wilcox
Swiftcor Aerospace
Mike Carter
Michael Carter
I.T. Director
6863 Indy Drive.
Belvidere, IL 61008
Phone: 815-544-2177
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Gary Wilcox
Mike,
Gary Wilcox
Swiftcor Aerospace
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
Mike Carter
[cid:image001.png@01CCD5D4.7E924540<mailto:image001.png%4001CCD5D4.7E924540>
Michael Carter
I.T. Director
6863 Indy Drive.
Belvidere, IL 61008
Phone: 815-544-2177
If the barcode is on a crystal reports form you can't reference the database
field directly. You need to set up a formula that uses the cstr function.
Something like:
CStr({ShipHead.PackNum},0)
Then put the formula field on the form.
Mike Carter
Sent: Wednesday, January 18, 2012 11:27 AM
Mike,
Gary Wilcox
Swiftcor Aerospace
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>] On
Behalf Of
Mike Carter
Michael Carter
I.T. Director
6863 Indy Drive.
Belvidere, IL 61008
Phone: 815-544-2177
Gene
> Thanks
> Mike,
> Gary Wilcox
> Swiftcor Aerospace
> Mike Carter
> Thanks
> Michael Carter
> I.T. Director
> 6863 Indy Drive.
> Belvidere, IL 61008
> Phone: 815-544-2177
Thank you
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of gmack110256
Gene
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Mike Carter <mcarter@...<mailto:mcarter@...>> wrote:
> Thanks
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Gary Wilcox
> Mike,
> Gary Wilcox
> Swiftcor Aerospace
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of
> Mike Carter
> To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> Thanks
> Michael Carter
> I.T. Director
> 6863 Indy Drive.
> Belvidere, IL 61008
> Phone: 815-544-2177
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Â
Thank you
Gene
> Thanks
> Mike,
> Gary Wilcox
> Swiftcor Aerospace
> Mike Carter
> Thanks
> Michael Carter
> I.T. Director
> 6863 Indy Drive.
> Belvidere, IL 61008
> Phone: 815-544-2177
Mike
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Steven Gotschall
From: Mike Carter <mcarter@...<mailto:mcarter%40youngbergindustries.com>>
To: "vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>" <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>>
Thank you
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of gmack110256
Gene
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, Mike Carter <mcarter@...<mailto:mcarter@...<mailto:mcarter@...%3cmailto:mcarter@...>>> wrote:
> Thanks
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of Gary Wilcox
> Mike,
> Gary Wilcox
> Swiftcor Aerospace
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of
> Mike Carter
> To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> Thanks
> Michael Carter
> I.T. Director
> 6863 Indy Drive.
> Belvidere, IL 61008
> Phone: 815-544-2177
