After you have ODBC configured open Access. Choose New Table, Link
Table. Change Files of Type to ODBC Databases. Choose your Data
Source name. A list of Vantage Tables will appear, choose the ones
you want to connect. Then the tables will appear in Access. After
that I always create a Make Table Query to create an Access Table
from the Linked Table with the fields I want to use, it will improve
performance by not using a live linked table to create reports.
You'll wait a little while the tables are made, but the reports will
run instantly. After I have Access tables for each linked table,
then I create whatever queries and reports I need.
HTH,
Brian Stenglein
Clow Stamping Co.
HTH,
Brian Stenglein
Clow Stamping Co.
--- In vantage@yahoogroups.com, "mansfield1024" <johnm@g...> wrote:
> Hi to all,
> I would like to set up Access using the ODBC connection.
> First I want to know the risks of writing to Progress Vantage.
> I think all I have to do is link to the Merant driver for Vantage.
> All of the tables should be visable, I should then be able to
> create a querry then a report.
> Does this sound right or am I missing something?
> Thanks,
> John Mansfield
> General Sheet Metal
