Todd,
Thanks for the Tip !
Ray
Sent: Friday, July 06, 2001 11:56 AM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Vantage Master Import Utility
Raymond,
Along the same lines ... You can export from V4 and then import the data
into MS-Access. Then alter the table / fields as required using mass
changes etc .... and then export from MS-Access a "New" csv file which you
can then import into V 3.0
I did this several years ago when I wanted to install a clean version of
Vantage. I exported all of my master tables and imported them into a clean
DB with the exception of the BOM master files. Since we had accumulated
tons of garbage over the years I exported the BOM master files and a report
showing all of the item masters that had been used in the past 18 months.
After pulling the tables into MS-Access I simply cross linked the usage
table to the master tables and deleted all of the garbage. After exported
the new "Trimmed" down master tables from Access I was able to import them
into the new DB. About 8 hrs of my time to figure the whole thing out as
opposed to manually deleting 5-10,000 obsolete masters.
Todd Anderson
J. Rubin & Co.
Sent: Friday, July 06, 2001 10:46 AM
OOPS,
I misread your intent of taking V4 data back to V3. My premise holds but is
easier since you will need to remove some columns of data from the CSV file
before importing it into V3. Just make sure you follow the outline from the
Data Dictionary of each version to know which data fields are new to V4.
H. Dale Puls
Sent: Friday, July 06, 2001 10:22 AM
To: 'Vantage (E-mail)
Subject: [Vantage] Vantage Master Import Utility
Hi all !
I am a new member to this group and have been using Vantage version 4 for
about a year now ! I was wondering if any of you have had problems using the
master import utility ? I have been trying to update the parts table on a
standalone version of Vantage. The standalone pc has version 3 of Vantage
installed ! I have exported the table using the Master Export Utility from
a version 4 of Vantage and I am trying to import the text file (CSV) . The
only error message that error log is showing is "UNABLE TO IMPORT FILE". No
other message is written in the error log. Can anyone offer any insight to
what could be the problem !
Raymond Quesnel
Systems Norbec
Support Technician
rquesnel@...
Tel:(450)649-4346
Fax:(450)641-4657
To access the Files Section of our Yahoo!Group for Report Builder and
Crystal Reports and other 'goodies', please go to:
<http://groups.yahoo.com/group/vantage/files/.> Note: You must have
already
linked your email address to a yahoo id to enable access.
<http://docs.yahoo.com/info/terms/>
already linked your email address to a yahoo id to enable access.
Your use of Yahoo! Groups is subject to the Yahoo! Terms of
<http://docs.yahoo.com/info/terms/> Service.
http://groups.yahoo.com/group/vantage/files/. Note: You must have already
Ray
Raymond,
Todd Anderson
J. Rubin & Co.
OOPS,
H. Dale Puls
Hi all !
Raymond Quesnel
Systems Norbec
Support Technician
rquesnel@...
Tel:(450)649-4346
Fax:(450)641-4657
already
