Vantage on Microsoft SQL Server
We migrated to SQL Server and was there for 6 months. We went back to
Progress in March of this year. We have one of the fastest networks and
servers possible and it was still allot slower then Progress. We eventually
got the speed to an acceptable level. Our problem was with data corruption.
It seemed like almost every time we applied a patch it would corrupt
something. We are still dealing with problems that was caused by the time
spent on SQL Server. When we made the change back in March, I was told that
there was no other SQL Server users left. I also was frustrated when
calling Tech support. When I mentioned that I was on SQL Server, I often
imagined the Tech support person with the "deer in the headlights" look
about them. One way I got by allot of the speed issues was to run as many
users as possible on Terminal Services from the Vantage server. Although
you should normally not run server applications such as SQL Server on a
Terminal server, this was one of the few things I could do that made a huge
difference.
A few other things that where problems.
1) Priority dispatch report that takes 30 sec on Progress takes 30-45
minutes on SQL Server
2) Global Finite Scheduling took over 24 hours to run.
3) Installation and upgrade instructions where obviously untested.
Hope you have better luck then we did. I have a Priority Dispatch report
written in MS Access 2000 that runs on SQL Server much faster then the
Vantage report if you would like a copy of it. I believe I still have a
copy of all of our custom reports written in Access if you would like them
let me know.
If you have any questions, feel free to give me a call.
Jeremy Leonard
IT Manager
K-T Corporation
317-398-6684
Sent: Wednesday, November 27, 2002 8:00 AM
Subject: [Vantage] Vantage on Microsoft SQL Server
Hi all,
Is anyone out there using the version of Vantage that runs on Microsoft
SQL? We are thinking of moving to it. I would like to hear about any
problems or performance issues from anyone using it. I would also like
to hear about the Progress to SQL conversion process.
Chris
Hi all,
Chris
We are about to go live with Vantage on SQL. During testing, there were all sorts of issues we had with Vantage, many of which Epicor had not encountered before. The unofficial line was that we were running Vantage on SQL which had a very small user base, and therefore may not have the same level of development testing and support.
One of the most annoying things is an apparent lag between entry of data and posting of that data for immediate use in another screen. Our local Epicor consultant have seen this himself. Again, the unofficial line is "the introduction of another layer of complexity with SQL may contribute to the unexpected behaviour." In other words, we don't know and don't want to know.
I am not an IT person and couldn't care less about the difference MS SQL and Progress. A hotshot independent consultant recommended MS SQL anticipating compatibility with bolt-on programs, which in hindsight is neither here nor there. However, when a lot of performance issues raised always come back, unofficially of course, as related to SQL and the small Vantage user base for it, I could only say "BUYER BEWARE."
Gil Amilbangsa
Australian Healthcare Equipment
gil.amilbangsa@...
Sent: Thursday, November 28, 2002 12:00 AM
Hi all,
Chris
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/M=237459.2675695.4055211.2225243/D=egroupweb/S=1705007183:HM/A=1267611/R=0/*http://ad.doubleclick.net/jump/N2524.Yahoo/B1071650;sz=300x250;ord=1038401978260178?>
<http://us.adserver.yahoo.com/l?M=237459.2675695.4055211.2225243/D=egroupmail/S=:HM/A=1267611/rand=831942648>
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
