Vantage Service Connect and Database Servers
Second that..
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-0590
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
Of Ned
Sent: Monday, June 27, 2011 1:56 PM
Subject: RE: [Vantage] Vantage Service Connect and Database Servers
No, your best option is to use a completely separate server for a
separate
service connect instance for each DB you want to connect to.
Behalf Of
jeff_o_h
Sent: Monday, June 27, 2011 11:41 AM
Subject: [Vantage] Vantage Service Connect and Database Servers
I am getting started with Service Connect and have a question. First, we
are
on Vantage version 8.03.408. We use Progress as our DB and we have 3
environments to work in test, pilot and live. When I use the
WS-Configuration tool to import a service like the POService I specify
the
database connection information. So I may want to use TEST to start with
but need to change that when it is time to implement. Is there a way to
change the database connection information? Can I specify the database
info
in the Workflow?
Thanks in Advance,
Jeff Hanka
senior application developer
1211 Old Albany Road, Thomasville, GA 31792 www.TECTcorp.com
have
and
I am getting started with Service Connect and have a question. First, we are on Vantage version 8.03.408. We use Progress as our DB and we have 3 environments to work in test, pilot and live. When I use the WS-Configuration tool to import a service like the POService I specify the database connection information. So I may want to use TEST to start with but need to change that when it is time to implement. Is there a way to change the database connection information? Can I specify the database info in the Workflow?
Thanks in Advance,
Jeff Hanka
www.TECTcorp.com
No, your best option is to use a completely separate server for a separate
jeff_o_h
in the Workflow?
Thanks in Advance,
Jeff Hanka
