Rick,
We made the leap from 3.0 to 5.0 in July. I would recommend the Dump & Load as well.
We started Friday evening around 8 p.m. At 10 A.M. the next morning we had finished going to 4.0. By Sat. evening we were on 5.0. A few hours Sunday was spent debugging some things (like Custom Report Links), ODBC, etc.
We had done the client installs weeks before -- we did them as we could get to various machines. This saved time on the conversion weekend, although we did have to reinstall Progress on a few machines (this was what was causing some problems in Custom Report Links).
If you have specific questions, just ask.
Troy
Troy
----- Original Message -----
Sent: Tuesday, October 23, 2001 8:38 AM
Subject: [Vantage] 3.0 to 5.0
Has anybody out there done a 3.0 to 5.0 skip yet? We are planning to do
this before the end of the year, then go to 5.1 in the spring when we can
get a new server.
Our database is large, on the order of 1.2 gb, and was created in September
of 96. Should we maybe consider a dump and load to clean up some holes and
spead up the schema changes? I've done the 3 to 4 to 5 upgrade on a test
server a few times. The 3 to 4 has always gone just fine, but the 4 to 5
has not. One time it stalled for days on the schema changes and the next
time it went through without a hitch.
I will probably only have a Friday at noon to Sunday evening to pull this
off (including installation of 75 clients), so any problems or advice would
be greatly appreciated.
Rick
Yahoo! Groups Sponsor
