5.1 Custom RB Reports on Vantage menu
At 08:04 AM 12/19/2001 -0500, you wrote:
>There are no error boxes or filters behind the report.... The reports point
>to a script which generates input boxes for variables such as job number,
>and, check boxes for subassembly, and a run button.... Each reports works
>fine in the report builder...
I didn't have a gray screen, but did have reports that worked in R.B. but
not from the menu after out 5.0 upgrade.
Try opening the report in R.B. and do a "purge calculations". Turned out,
calculated fields that were defined, but not printed, could reference
invalid fields and not create any warnings in R.B. - but the did cause
reports to fail when run from the Vantage menus.
-Wayne Cox
Next oddity in my 5.1 upgrade; after a user runs a customized RB report
from the Vantage menu and closes the window, the Vantage menu refreshes to
solid gray. The only option for the user is to log out, or change user ID,
and start a new session... This only happens on customized reports...
Any suggestions?
TIA,
Paul Siebers
Have not seen this but, in 5.1 the report filter box often opens behind the
Vantage screens so users run it again and get an error regarding a rbrun.txt
file being open. Close the error and the filter screen and all is well......
Sent: Tuesday, December 18, 2001 11:45 AM
To: 'vantage@yahoogroups.com'
Subject: [Vantage] 5.1 Custom RB Reports on Vantage menu
Any suggestions?
TIA,
Paul Siebers
Yahoo! Groups Sponsor
<http://rd.yahoo.com/M=215839.1778785.3296727.1261774/D=egroupweb/S=17050071
83:HM/A=868539/R=0/*http://zappos.zappos.com/bin/zapposset?ref=yahoogroups2>
<http://us.adserver.yahoo.com/l?M=215839.1778785.3296727.1261774/D=egroupmai
l/S=1705007183:HM/A=868539/rand=715308328>
Does the report work OK in Report Builder Application? It may be that there is a new/changed field in 5.1 that the report is hiccupping on.
Troy Funte
Liberty Electronics
----- Original Message -----
Sent: Tuesday, December 18, 2001 11:53 AM
Subject: RE: [Vantage] 5.1 Custom RB Reports on Vantage menu
Any suggestions?
TIA,
Paul Siebers
ADVERTISEMENT
Paul
Sent: Wednesday, December 19, 2001 7:41 AM
Subject: Re: [Vantage] 5.1 Custom RB Reports on Vantage menu
Troy Funte
Liberty Electronics
the
rbrun.txt
well......
ID,
Any suggestions?
TIA,
Paul Siebers
<http://zappos.zappos.com/bin/zapposset?ref=yahoogroups2> >
have
< http://groups.yahoo.com/group/vantage/files/.
<http://groups.yahoo.com/group/vantage/files/.> >
< http://groups.yahoo.com/group/vantage/messages
<http://groups.yahoo.com/group/vantage/messages> >
< http://groups.yahoo.com/group/vantage/links
<http://groups.yahoo.com/group/vantage/links> >
< http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> >
ADVERTISEMENT
ADVERTISEMENT
<http://rd.yahoo.com/M=178320.1681224.3270152.1261774/D=egroupweb/S=17050071
83:HM/A=879171/R=0/*http://www.fastweb.com/ib/yahoo-57f>
<http://us.adserver.yahoo.com/l?M=178320.1681224.3270152.1261774/D=egroupmai
l/S=1705007183:HM/A=879171/rand=580984542>
Actually, here is one of the offending scripts. Vantage gui disappears as
soon as the report opens. When I close the report before running it it
opens to a full RB screen, which "wipes out" the gui.
Paul
/* rbtest.p
Running Report Engine from an application - PRINTRB INTERFACE.
Made from sample program rbfilt4.p
Displaying a report as saved by Report Builder. */
DEF BUTTON exit-button LABEL "Exit".
DEF BUTTON run-button LABEL "Run Report".
DEF VAR cRBPrinter as char no-undo.
DEF VAR jobnum AS CHAR FORMAT "x(12)" no-undo.
def var k as char no-undo.
def var kap as char init "'" no-undo.
def var kpart as char init "' and JobAsmbl.PartNum <= '300-000'" no-undo.
DEF VAR rb-filterx AS CHAR no-undo.
def var rb-reportx as char init "x:\vantage\ud\bpmenu.prl" no-undo.
DEF VAR toggle1 as log init no
LABEL "Change Default Printer" VIEW-AS toggle-box size 30 by 1.19 no-undo.
DEF VAR toggle2 as log init no
LABEL "Select All Subassemblies" VIEW-AS toggle-box size 30 by 1.19
no-undo.
def var xpart as char format "x(30)".
xpart = kpart.
FORM skip(1) "Job Number" at 10
jobnum at 10 SKIP (1)
toggle2 at 10 skip (1)
toggle1 at 10 skip (1)
exit-button run-button AT 23 WITH FRAME TEST-FRAME CENTERED ROW 10 THREE-D
NO-LABELS TITLE "Purchased Parts List".
on leave of jobnum assign jobnum.
on value-changed of toggle1 in frame test-frame cRBPrinter = "?".
on value-changed of toggle2 in frame test-frame do.
assign toggle2.
if toggle2 = no then xpart = kpart.
else xpart = kap.
end.
enable toggle1 toggle2 with frame test-frame.
ON CHOOSE of exit-button hide frame test-frame.
ON CHOOSE OF run-button do.
HIDE FRAME TEST-FRAME.
session:set-wait-state("general").
if os-getenv("b") = "c" then rb-reportx = "d:\c\bpa\bpmenu.prl".
rb-filterx = "Jobhead.Company = 'bpa' and JobHead.JobNum = '" + jobnum +
xpart.
RUN aderb\_printrb(
rb-reportx, /* RB-REPORT-LIBRARY */
"PPL", /* RB-REPORT-NAME */
k, /* RB-DB-CONNECTION */
"O", /* RB-INCLUDE-RECORDS */
rb-filterx, /* RB-FILTER */
k, /* RB-MEMO-FILE */
"D", /* RB-PRINT-DESTINATION */
cRBPrinter, /* RB-PRINTER-NAME */
k, /* RB-PRINTER-PORT */
k, /* RB-OUTPUT-FILE */
0, /* RB-NUMBER-COPIES - zero */
0, /* RB-BEGIN-PAGE - zero */
0, /* RB-END-PAGE - zero */
no, /* RB-TEST-PATTERN */
k, /* RB-WINDOW-TITLE */
yes, /* RB-DISPLAY-ERRORS */
yes, /* RB-DISPLAY-STATUS */
no, /* RB-NO-WAIT */
k). /* RB-OTHER-PARAMETERS */
session:set-wait-state(k).
END.
ENABLE jobnum exit-button run-button WITH FRAME test-frame.
wait-for CHOOSE OF exit-button or CHOOSE OF run-button.
